Hi during first discover, Dude Beta 3 fresh install, devices appear and after some seconds disappear.
I would like to have different maps:
first map: 192.168.1.0/24
second map: 192.168.2.0/24
ecc.
PC TCP/IP subnet it’s corrects to view the maps.
Cetalfio
Are all the services and device types allowed to be discovered on your Device Discovery settings?
I’ve selected only PING services and Dude and Mikrotik devices, I would like to monitor only RB and if they are ok or if they have problems on the network reachability,
Cetalfio
I don’t use auto discover but I would imagine that services need to be allowed and or required to automatically identify a device and have the services installed automatically.
Here is what you should do, manually add a device then on the services tab click discover. You will see each service the device supports get added to the device. If they all get removed automatically then you have the incorrect combination of allowed and required for that device type. Once you get services to stick on a device auto discover should work for that device and they should not disappear from your map.
I think you could check under discover->advanced “add serviceless” to have devices with 0 services stay discovered.
GL
Lebowski
