Hey!
I have a 3G / LTE modem Huawei E3372h-153 modem connected to the Mikrotik RB912UAG-5HPnD-OUT.
I set it up for a long time according to the instructions that are on the Internet. However, the Wi-Fi mode couldn’t be done. Wi-Fi connection. It simply doesn’t exist. What is the problem?
Indeed.
When I unboxed a new LG G6, it didn’t see WiFi AP on channel 13. After I put in SIM card and it registered to mobile network, it obviously discovered it was in Europe .. and it started to see the “invisible” AP.
Thanks for the answer. However, it does not work. Maybe I made a mistake somewhere in the settings. Tell me, how can I show you a log or some kind of report so that you watch it?
This radio interface supports 5GHz only.
You could add a 2.4GHz card to it , this one will surely do well: https://mikrotik.com/product/R11e-2HPnD
Add two MMCX pigtails and antennas and you have a decent dual-band AP
