Devices Showing Offline After Upgrade to 6.44.5
I just upgraded my Dude server and a few devices to 6.44.5, all of the 6.44.5 devices are showing offline and all of my 6.43.16 devices are showing online. I downgraded one of the 6.44.5 devices to 6.43.16 and it now shows online.
Is there an issue with Dude or SNMP in 6.44.5?
Mine’s working OK.
What Service or Services, specifically, are you using?
The SNMP “Router” probe.
That’s not something I ever use, but I tried on one of my routers, and it comes up OK.
Yeah I’ve never had a problem with it until today. Just downgraded a second device back to 6.43.16 and it immediately came back up as online inside Dude. No configuration change.
Which SNMP version are you using? If Version 3, which Security option?
Hi
I have configured snmp v3 authorize with 6.42.12 routeros. I updated the CPE to 6.44.5 and now from The Dude I can`t see snmp information of any CPE with 6.44.5 version, with 6.42.12 no problems.
If I change snmp to v1 or v2 in the CPE from The Dude I can see the oid tree from snmpwalk but from snmp tab of the CPE device, all fields blank.
Does anyone know how to fix it?
Thank you.
Glad to know I am not the only one having the issue. I downgraded all of my devices back to 6.42.16 to resolve the problem until a new release comes out.
http://forum.mikrotik.com/t/v6-45-1-stable-is-released/131227/361
