Hello all.
I have 2 mikrotik routers in different regions, router A and 1/router B. there are many customers behind each router.
I have better global internet traffic at router A. So, I decided to allow router B users use router A as their global internet gateway. Here is what I did:
- Created ipip tunnel between these routers,
- marked router B users connection as Local_traffic_connection;
- marked router B users Local_traffic_connection to global IP list as Global_connection;
- Marked packets of Global_connection as Global_connection_packets (no passthrough);
- Created routing-mark for these packets and in the gateway I pointed IPIP tunnel interface IP of router A.
Unfortunately, it did not work. Can you suggest me what might cause the problem?
