DFS no-radar detect
I tried to set DFS mode to no radar detect, and it scans channels but channel stays the same, then I set other APs to same channel and DFS did not changed channel just left channel I set earlier.
Why is that ?
Are U sure? Try to scan it with client device. DFS doesn’t change frequency in wireless care properties. You could put there what ever you like…
Care properties?
What is that. DFS is useful on AP interface, what good is it for client ?
no, he meant to say that it doesn’t matter what you see in the “frequency” setting, it will actually use another frequency. use a client device to Scan for APs and you will see what frequency your AP is using.
or do an interface monitor command on the ap.
Stefan
oh, ok thx . . . :slight_smile:
