I got the bwta8 on som etest sites but DFS still not working. In fact the wireless select everytime the firs frequency into the scan list, also if it is used by an adiacent AP.
So please take a look into it. This is my wirelss config:
name=“wlan1” mtu=1500 mac-address=00:0B:6B:0A:96:70 arp=enabled disable-running-check=no
interface-type=Atheros AR5213 radio-name=“000B6B0A9670” mode=ap-bridge
ssid=“Roccac2_Sudest” area=“” frequency-mode=regulatory-domain country=italy
antenna-gain=0 frequency=5700 band=5ghz
scan-list=5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700 rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no default-forwarding=no
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=enabled hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00
Regards
