dhc-client will NOT go away - is this a problem ?
I am pulling my hair out !!!
dhcp-client will NOT go away !!!
I have a CHR 64-bit system v6.41.1 (virtual running on VMware ESXi)
If I have a single IP address on ether1 -and- an IP address on the bridge (4 ethernet ports total and a bridge) , I can remove all dhcp-client settings and it works. I can reboot it and there is no dhcp-client on the system.
However , I have this problem where I can not remove all dhcp-client options using this config:
If I have a single IP address on ether1 -and- no other IP addresses (4 ethernet ports total and a bridge) , I can remove all dhcp-client settings and it works. However , when I reboot it , the dhcp-client shows up on a reboot. (every time I remove dhcp-client in the config , it shows back up on ether1)
Also - If I just disable the dhcp-client on ether1 and reboot it, I now have two dhcp-client lines in my config.
- One dhcp-client on ether1 is disabled
- and a second dhcp-client on ether1 that is enabled
WTF am I doing wrong ? Or is this an un-documented feature (another word for a bug)
Note: neither CHR has a default route ( 0.0.0.0/ ) - or any other static routed
ALSO - I am able to repeat this dhcp-client problem showing up on another different CHR v6.41.1 router.
edit note - If I remove the dhcp package and reboot - there is no dhcp-client injected into the config. However , when I re-enable the dhcp package and reboot , the dhcp-client is re-inserted.
I want the dhcp package because later I will configure a dhcp-server for some other interfaces.
North Idaho Tom Jones
