Hi all!
We try to use Mikrotik as router and DHCP server.
Switches send DHCP packets to Mtik, Mtik make req to Radius server and receive
dhcp pool name, speed limits…
All work good, but small problem.. No accounting
And i don’t know IP address of user (from pool), traffic.
And don’t know when user stops use address
Maybe it’s possible:
Send Accounting-Start packet with IP address, when lease and queue created and up?
Send Accounting-Stop packet with traffic from queue (if created), when lease dropped?
Many people try to use Opt82 instead PPPxx, it’s may be a good solution.
I just setup DHCP with RADIUS auth yesterday and thought I had done something wrong when I didn’t see accounting start packets. I was expecting a start packet on initial assignment and a stop packet when the lease expires. Perhaps an accounting update packet when the lease is renewed.
Also, I thought I would see an auth request every time the lease was renewed, but I haven’t seen any auth requests after the initial request unless I delete the dynamic lease on the mikrotik before the lease is renewed.
We need the accounting packets in an ISP setting to tell us who was using a particular IP 3 months ago without trawling through syslog server archives.
it’s how it works: if you don’t set lease timeout in RADIUS Access-Accept, then the value from DHCP server settings is used, and no RADIUS Request is made for lease renewals; if you return timeout from RADIUS, then any renews of that lease will require RADIUS authorization - that’s what you’re looking for
dear Chupaka, can you give me some example of how to configure RB DHCP Server to resend option82 data of DHCP request (received from some port L2 commutator) to freeRadius server connected directly to RB???
I’m trying to implement MAC-independent PORT-binded connection to every customer.
I mean, for example, any device with any MAC connected to port 1 of commutator will take from DHCP Server (RB) only one IP-address (192.168.0.1 for example), and no another. If the same device (or any) will connect to another port (for ex. 2) so it will take another IP (192.168.0.2 for ex.).
PLZ
Turn on system->logging->topic dhcp and you will see in og file all information from DHCP request sending to radius. Mikrotik sends probably all information from dhcp request packets, but the correct way to dump and check.
Has anyone come up with a way to get the radius accounting information without making users change how their equipment is setup by using mac-auth in the hotspot functionality?
It looks to me like it should be possible to enable hotspot on the customer facing interface and deal with their already DHCP assigned IP address without any login popups. I just don’t have any experience with hotspot at all and haven’t had time to experiment yet.
Any news about support of accounting for Radius DHCP ? We are using API for gathering information about DHCP radius sessions, but with Radius accounting it should be simpler and standartized.
Yes, I believe there are many people interested in this topic. Any response would be pleased. “We plan to implement” or “We don’t plan to implement” would be sufficient .
