DHCP alerts, arrays
It appears that the DHCP alerts can’t use array variables.
I can take the same script and copy it to /system scripts as a stand alone and it will run fine.
If it point the DHCP alert to that same working script I created in /system scripts, it will not pull the values for the array variable. It also does this if the code is entered directly in the alert action. The action will run fine without using array variables.
I’d like to use an array. Has anyone experienced the same issue? Is this a bug?
