I’m trying to migrate a Cisco router to Mikrotik.
It currently runs a DHCP server over multiple VLANs with each VLAN configured as ip unnumbered, something like below. Can Mikrotik support this? or do I need to assign an IP address to each VLAN? Thanks in advance.
interface Loopback0
ip address 172.17.12.1 255.255.255.0
interface FastEthernet0/1.101
encapsulation dot1Q 101
ip unnumbered Loopback0
ip helper-address 172.17.11.3
interface FastEthernet0/1.102
encapsulation dot1Q 102
interface FastEthernet0/1.103
encapsulation dot1Q 103
Thank you for your reply. Yes I know it’s possible with having an IP for each VLAN but if there are hundreds of VLANs it’s not very practical. Also if only one IP needs to be assigned by DHCP to a VLAN, a /30 needs to be assigned and wasting IP address resource.
Is there any other way of having DHCP running over hundreds of interfaces/VLANs without having IP on each interface in Mikrotik Router OS?
No, not unless you bridge them all into one another forming one large broadcast domain, which presumably defeats the purpose. RouterOS doesn’t have the concept of unnumbered interfaces. If you need that feature stick with a platform that supports it.
