DHCP and PPPoE
I am currently using PPPoE to authenticate clients to my router.
We are going to being using DHCP with Static only mac filtering.
Can I ad my server to the same port as the PPPoeE, Use the same pool in both and then change all the PPPoE clients to DHCP without any issues?
Yes, you can use same pool for DHCP. I think it will be no problem.
Thank you.
