DHCP and RADIUS - attribute changes
I am running dhcp with radius enabled :
I am using radius attributes to set IP address and rate limit.
When client renews lease, changes to IP address and rate limit made on radius server are not reflected.
What do I need to do to make this work?
Thanks,
-dan
Fixed.
Have to set Session-Timeout attribute to have mikrotik check radius attributes at renewal time.
From what I see, the lease-time in DHCP-server config does not check attributes for changes.
Hello
I know this a old topic.
I am implementing a similar setup with a web frontend to manage customers.
How do you manage disconnections to non paying customers?
