I have a “CRS125-24G-1S-2HnD” with port 24 connected to my internet connection. Currently on the internet port I have an IP address that is received from my ISP’s DHCP server as well as a static address that I have assigned to the interface.
I was all web browsing to occur via the dynamic address and allow for incoming internal services via the static address.
Initially this works fine, if I browse to a website like https://whatismyipaddress.com/ my public address is displayed, however when the DHCP lease refreshes and I browse to https://whatismyipaddress.com/ it then displays my static ip address. Each time this happens, I disable the static address on the interface and re-enable to make the DHCP address take priority again.
My question, how do I get the DHCP address to permanently take priority over the interface? I want the static address to only be used incomming connections to internally hosted services.
I think I explained myself badly. The following depicts my config with regards to IP addresses and routes. There is a dynamic route and IP address (xxx.xxx.164.216) obtained from the ISP DHCP. There is also a statically assigned IP address (xxx.xxx.164.221) to the same interface. Looking at the routes, you notice that the dynamic route does not have a PREF-SRC and it seems that this cannot be set manually.
When initially visiting the https://whatismyipaddress.com website, it reports back that my public IP address is xxx.xxx.164.216. If I then renew the DHCP lease and revisit the https://whatismyipaddress.com website, it reports my public IP address as xxx.xxx.164.221.
I do not want my users to browse the internet as xxx.xxx.164.221, instead I want xxx.xxx.164.221 to be used only for incoming connections that I make available via NAT rules.
Any advice would be greatly appreciated.
[admin@1000_MTIK_CRS-1-24Port] /ip address> pri
# ADDRESS NETWORK INTERFACE
0 10.11.0.250/24 10.11.0.0 PORT2 - LAN
1 XI 192.168.10.200/24 192.168.10.0 PORT1 - Internet
2 10.11.3.251/24 10.11.3.0 PORT23-WAN-1003
3 10.10.0.1/30 10.10.0.0 PORT24-WAN-1001
4 192.168.0.250/24 192.168.0.0 PORT2 - LAN
5 10.11.100.205/30 10.11.100.204 VLAN1000
6 xxx.xxx.164.221/24 xxx.xxx.164.0 PORT21-INTERNET-FIBRE
7 10.11.100.221/30 10.11.100.220 VLAN3000
8 D xxx.xxx.164.216/24 xxx.xxx.164.0 PORT21-INTERNET-FIBRE
[admin@1000_MTIK_CRS-1-24Port] /ip route> print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 197.234.164.1 150
1 ADC 10.10.0.0/30 10.10.0.1 xxxx.WAN.Bridge 0
2 A S 10.11.0.0/16 10.11.3.251 10.11.3.244 125
3 S 10.11.0.0/16 10.11.100.206 130
4 ADC 10.11.0.0/24 10.11.0.250 xxxx.LAN.Bridge 0
5 A S 10.11.1.0/24 10.11.3.250 120
6 ADC 10.11.3.0/24 10.11.3.251 xxxx.WAN.Bridge 0
7 A S 10.11.4.0/24 10.11.3.245 120
8 A S 10.11.7.0/24 10.11.3.246 120
9 A S 10.11.10.0/24 10.11.100.206 120
10 A S 10.11.15.0/24 10.11.3.250 120
11 A S 10.11.17.0/24 10.11.0.250 10.11.100.206 120
12 A S 10.11.20.0/24 10.11.0.250 10.11.100.206 120
13 A S 10.11.24.0/24 10.11.0.208 120
14 A S 10.11.25.0/24 10.11.0.250 10.11.100.206 120
15 A S 10.11.100.0/24 10.11.100.206 120
16 ADC 10.11.100.204/30 10.11.100.205 VLAN1000 0
17 ADC 10.11.100.220/30 10.11.100.221 VLAN3000 0
18 A S 172.16.0.0/12 10.11.100.206 130
19 A S 192.168.0.0/16 10.11.100.206 130
20 ADC 192.168.0.0/24 192.168.0.250 xxxx.LAN.Bridge 0
21 A S 192.168.1.50/32 10.11.100.206 1
22 A S 192.168.2.0/24 10.11.100.206 120
23 ADC xxx.xxx.164.0/24 xxx.xxx.164.216 PORT21-INTERNET... 0
I think you are going to have to script your way out of this to get it to work the way you want 100% of the time.
Basically, you’re going to have to use action=src-nat instead of action=masquerade because masquerade is just going to use whatever it thinks the correct source IP address will be.
Set up src-nat rule(s) for host(s) that should be mapped to the static IP and then you’ll need a script that is triggered whenever the dhcp-client obtains a lease, which modifies the to-addresses=x.x.x.x option on the dynamic src-nat rule. You can use a comment as the way to select the “dynamic src-nat” rule.
It is also possible to put the default route for the fixed IP address in a different route table (type something in the “route mark” field, e.g. “static”)
and the under IP->route->rules add a rule with that static IP as the source address and a lookup in that table.
That way, the default route will not be available to any other traffic than the replies to traffic to that fixed address. All other traffic (including outgoing masquerade traffic)
will use only the main table, which is initialized by the DHCP client.
