DHCP and VLAN's
Greetings,
I’m new to MikroTik.
I cannot get Mikrotik on-board DHCP server to lease address over native VLAN (VID 1) in bridge with other VLAN (VID 1952). I don’t want DHCP on VID 1952, only on VID 1.
Port 1 will be WAN but don’t have it set up yet.
Port 2 will be hybrid port: VID 1952 tagged, VID 1 untagged. Bridge will be managed through VID 1952.
Port 3 VID 1 untagged.
Port 4 VID 1952 untagged.
Port 5 VID 1952 untagged.
Live capture in Wireshark with filter udp.port==68 shows client connected to Port 3 sending DHCP Discover messages but nothing else related to DHCP showing and can’t get a lease from Mikrotik VID 1 DHCP server.
Using RB960PGS hEX PoE OS 6.44.3
What am I missing? I appreciate any help.
add admin-mac=B8:69:F4:B5:68:0D auto-mac=no comment=defconf \
    ingress-filtering=yes name=bridge protocol-mode=none pvid=1952 \
    vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan1 vlan-id=1
set 1 default-vlan-id=1 vlan-header=add-if-missing vlan-mode=fallback
set 2 default-vlan-id=1 vlan-header=always-strip vlan-mode=fallback
set 3 default-vlan-id=1952 vlan-header=always-strip vlan-mode=fallback
set 4 default-vlan-id=1952 vlan-header=always-strip vlan-mode=fallback
set 5 default-vlan-id=1952 vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.0.10-192.168.0.254
add address-pool=dhcp_pool0 disabled=no interface=vlan1 name=dhcp1
add bridge=bridge comment=defconf interface=ether4 pvid=1952
add bridge=bridge comment=defconf interface=ether5 pvid=1952
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge interface=vlan1
/interface bridge vlan
add bridge=bridge tagged=ether2 untagged=ether4,ether5 vlan-ids=1952
add independent-learning=no ports=ether2,ether3 switch=switch1 vlan-id=1
add independent-learning=no ports=ether2,ether4,ether5,switch1-cpu switch=\
    switch1 vlan-id=1952
add address=10.254.4.39/23 comment=defconf interface=bridge network=\
    10.254.4.0
add address=192.168.0.1/24 interface=vlan1 network=192.168.0.0
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/tool mac-server
/tool mac-server mac-winbox
You are attempting to mix a VLAN-aware bridge /interface bridge add … vlan-filtering=yes and switch chips VLANs /interface ethernet switch port.
This is inadvisable - either use a non-VLAN-aware bridge (these are transparent to VLANs) and configure switch chip VLANs, OR a VLAN-aware bridge with VLAN membership defined in /interface bridge vlan & PVIDs defined in /interface bridge port
Using VLAN-aware bridges disables hardware switching so will increase the CPU load.
Also not recommended to use vlan1 for an actual vlan…
