I have a weird problem with a new MT router set up that is driving me nuts. I have several MT systems running but this one will not issue a IP to any Tranzeo CPE’s. The system is as follows
- rap1d board with 2.8.23 level 3 where I am using the ethernet ports only for in and out. The AP is Tranzeo’s TR-4500
The above system will not assign any IP’s to the CPE’s, such as the 80-15’s or the 200-15’s. But will assign to my PDA and laptop with a Proxim card in it.
I have called Tranzeo and the tech told me that there is a problem in the MT code. I started to think on this and I dont belive this is truely it. I have a second system running that is as follows.
- rap1d board with 2.8.23 level 5 using a CM9 as the AP
This one works with the 200-15’s with no problems but seems to have Issues with the 80-15 but it gets the IP assigned when I fiddle with the radios IP settings and set it to look for a DHCP address in the 80-15
Things get realy confusing is the third system that I am running.
- 150mhz PC with 2.8.21 level 4 using a Tranzeo TR-4500
This last system seems to work flawlessly. The 200-15’s and the 80-15’s work without a problem.
Can any one shed some light on the problem.
I love the MT software and I wont change to something else just to use the CPE’s.
I dont think that MT is a problem but I sure would like some input.
For now I am setting the 80-15’s up as a Static IP but I sure would like to go back to Dia.
Mike
