Hello. I can not make the following scheme work.
Mikrotik CHR ether1 - internet
Mikrotik AP ether1 - internet
DHCP SERVER —> CHR.ether2 —> l2tp server → INTERNET —> NAT —> l2tp client —> AP.wlan1 —> DHCP Client
it is necessary that the access point which is behind nat gave dhcp from the server which is connected to ether2 mikrotik chr. I am use https://wiki.mikrotik.com/wiki/Manual:BCP_bridging_(PPP_tunnel_bridging)
Access point config
add admin-mac=CC:2D:E0:5A:C3:3E auto-mac=no fast-forward=no name=bridge-remote
/interface wireless
set [ find default-name=wlan1 ] disabled=no frequency=auto mode=ap-bridge ssid=test_2
set [ find default-name=wlan2 ] disabled=no mode=ap-bridge ssid=test_5
set [ find default=yes ] eap-methods="" supplicant-identity=MikroTik
/ip hotspot profile
/ppp profile
add bridge=bridge-remote change-tcp-mss=no name=profile1 use-encryption=yes
set *FFFFFFFE use-encryption=default
/interface l2tp-client
add connect-to=80.xxx.xxx.173 disabled=no max-mru=1600 name=l2tp-out1 password=ppp123 profile=profile1 user=ppp1
add bridge=bridge-remote interface=wlan1
add address=192.168.88.10/24 interface=bridge-remote network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=bridge-remote use-peer-dns=no use-peer-ntp=no
/ip firewall service-port
set pptp disabled=yes ports=1723
/system clock
set time-zone-name=Asia/Krasnoyarsk
/system identity
set name=AP
CHR config
add admin-mac=00:15:5D:C2:07:16 auto-mac=no fast-forward=no name=bridge-local
set [ find default-name=ether1 ] comment=Internet disable-running-check=no
set [ find default-name=ether2 ] comment="vlan 45" disable-running-check=no
add name=WAN
/ip ipsec peer profile
set [ find default=yes ] enc-algorithm=aes-256,aes-192,aes-128,3des
/ppp profile
add bridge=bridge-local name=l2tp-profile1
add bridge=bridge-local interface=ether2
/interface l2tp-server server
set authentication=mschap2 default-profile=default enabled=yes ipsec-secret=Im2aF1OnKO mrru=1600
add interface=ether1 list=WAN
add address=80.xxx.xxx.173/29 interface=ether1 network=80.xxx.xxx.xxx
add address=192.168.88.1/24 interface=bridge-local network=192.168.88.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid interface=bridge-local use-peer-dns=no use-peer-ntp=no
set allow-remote-requests=yes servers=80.xxx.xxx.xxx,80.xxx.xxx.xx
add action=passthrough chain=forward
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input src-address=80.xxx.xxx.xxx/25
add action=drop chain=input comment="defconf: drop all coming from WAN" in-interface-list=WAN
add action=accept chain=forward
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat disabled=yes ipsec-policy=out,none out-interface-list=WAN
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=80.xxx.xxx.174
/ppp secret
add name=ppp1 password=ppp123 profile=l2tp-profile1 service=l2tp
/system clock
/system identity
set name=CHR
If i am enable dhcp client on bridge remote on AP it not works. DHCP client on bridge on CHR work
Sorry for bad English.
