If the box is rebooted every couple of hours the problem does not occur. If left to run (say overnight) the lease will be dropped as soon as there is any high flow of traffic, the connection will re-establish but then drop again after a few minutes and so on. Whilst this is happening any Winbox connections are dropped too.
Nothing else appears in logs which are remote. Not seeing the diminishing memory reported elsewhere or the random reboots.
This is a new board, never run any other version. 6.0 issue or hardware?
Still experiencing the same issue. After a long idle period when traffic start again we see:
dhcp,debug,state dhcp-client on lte1 entering <stopped> state
192.168.1.3 dhcp,info dhcp-client on lte1 lost IP address XXX.XX.XXX.XX - lease stopped locally
192.168.1.3 dhcp,debug,packet dhcp-client on lte1 sending release with id 3179107531 to 255.255.255.255
