Recently my ISP changed, and everything works good expect my DHCP lease expires sometimes causing my connection to drop. I don’t really understand why this happens, and on logs all I see is requests which don’t seem to get a answer from my ISPs DHCP. I get a 2 hour lease, and on 1 hour it goes to renewing state like it is supposed to and sends a request to specified DHCP server, but nothing comes back. Sometimes quite rarely it does get an answer right away, most of the time it gets to rebinding state and starts sending requests to 255.255.255.255, yet there still is no response expect that at some point finally a DHCP server does answer and extends the lease. And on the occasion it expires, connection naturally drops, DHCP client state goes to “selecting”, starts sending discover to 255.255.255.255 several times until a DHCP server does answer and it gets an IP address once again and connection is restored. The lease has expired every 1-2 days once, most of the time it gets a answer just in time so it doesn’t expire but not always.
My router is a RB2011UiAS-RM, and I am connected through the SFP port with fiber and the ISP connection seems to come through a VLAN which I figured out using torch. Is there something obvious I am missing or have done wrong or does this seem to be a ISP issue? If a DHCP server does respond occasionally, and I am able to ping that specified DHCP server so it shouldn’t be that I am not able to reach it, what on earth could be wrong here? I already tried calling the ISP on Friday to ask how things look on their side since if I understand these logs, my router sends a request but it does not receive anything back, but I haven’t heard anything back yet since it was weekend. I can’t figure it out that there would be anything wrong on my side but I would like if someone more knowledgeable could check if I have made mistakes. I don’t really think there would be issues with network connectivity to ISP though since everything else works great expect DHCP has issues, so ISP side issue is really the only option which comes to my mind at this point but I don’t want to point fingers at somebody if it’s something stupid I have done.
Here is my config
# nov/23/2020 02:05:26 by RouterOS 6.47.7
# software id =
# model = 2011UiAS
# serial number =
add admin-mac=6C:3B:6B:28:85:C4 auto-mac=no name=bridge-vlan10
add name=bridge-vlan20
add name=bridge-vlan30
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=\
set [ find default-name=ether8 ] advertise=\
set [ find default-name=ether9 ] advertise=\
set [ find default-name=ether10 ] advertise=\
/interface gre
add allow-fast-path=no comment="LocalDNS:xxx.sn.mynetname.net RemoteD\
NS:xxx.sn.mynetname.net" !keepalive local-address=xx \
name=gre-tunnel1 remote-address=xx
/interface vlan
add interface=sfp1 name=WAN vlan-id=198
add interface=ether2 name=eth2-vlan10 vlan-id=10
add interface=ether2 name=eth2-vlan20 vlan-id=20
add interface=ether2 name=eth2-vlan30 vlan-id=30
add interface=ether6 name=eth6-vlan10 vlan-id=10
add interface=ether6 name=eth6-vlan20 vlan-id=20
add interface=ether6 name=eth6-vlan30 vlan-id=30
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip dhcp-server option
add code=66 name=option1 value="'172.16.20.16'"
add code=67 name=option2 value="'boot\\x86\\wdsnbp.com'"
add name=vlan10_pool ranges=172.16.10.2-172.16.10.254
add name=vlan20_pool ranges=172.16.20.230-172.16.20.254
add name=vlan30_pool ranges=172.16.30.2-172.16.30.254
add add-arp=yes address-pool=vlan10_pool disabled=no interface=bridge-vlan10 \
name=vlan10_dhcp
add add-arp=yes address-pool=vlan20_pool disabled=no interface=bridge-vlan20 \
name=vlan20_dhcp
add add-arp=yes address-pool=vlan30_pool disabled=no interface=bridge-vlan30 \
name=vlan30_dhcp
/routing ospf instance
set [ find default=yes ] in-filter=only-private out-filter=only-private \
redistribute-bgp=as-type-1 redistribute-connected=as-type-1 \
redistribute-other-ospf=as-type-1 redistribute-rip=as-type-1 \
redistribute-static=as-type-1
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge-vlan10 interface=eth2-vlan10
add bridge=bridge-vlan10 interface=ether3
add bridge=bridge-vlan10 interface=eth6-vlan10
add bridge=bridge-vlan20 interface=eth2-vlan20
add bridge=bridge-vlan20 interface=eth6-vlan20
add bridge=bridge-vlan30 interface=eth2-vlan30
add bridge=bridge-vlan30 interface=eth6-vlan30
add bridge=bridge-vlan10 interface=ether4
add bridge=bridge-vlan10 interface=ether5
set discover-interface-list=discover
add interface=sfp1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6 list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add interface=eth2-vlan10 list=discover
add interface=eth2-vlan20 list=discover
add interface=eth2-vlan30 list=discover
add interface=eth6-vlan10 list=discover
add interface=eth6-vlan20 list=discover
add interface=eth6-vlan30 list=discover
add interface=bridge-vlan10 list=discover
add interface=bridge-vlan20 list=discover
add interface=bridge-vlan30 list=discover
add interface=ether7 list=mactel
add interface=bridge-vlan10 list=mactel
add interface=ether7 list=mac-winbox
add interface=bridge-vlan20 list=mactel
add interface=bridge-vlan10 list=mac-winbox
add interface=bridge-vlan20 list=mac-winbox
add address=172.16.10.1/24 interface=bridge-vlan10 network=172.16.10.0
add address=172.16.20.1/24 interface=bridge-vlan20 network=172.16.20.0
add address=172.16.30.1/24 interface=bridge-vlan30 network=172.16.30.0
add address=172.16.254.1/30 interface=gre-tunnel1 network=172.16.254.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=no interface=WAN
/ip dhcp-server lease
add address=172.16.10.253 always-broadcast=yes mac-address=00:24:7E:00:27:DA \
server=vlan10_dhcp
add address=172.16.10.7 always-broadcast=yes client-id=1:cc:2d:e0:15:db:40 \
mac-address=CC:2D:E0:15:DB:40 server=vlan10_dhcp
add address=172.16.10.0/24 dns-server=172.16.20.11,172.16.20.13 gateway=\
172.16.10.1 netmask=24
add address=172.16.20.0/24 dns-server=172.16.20.11,172.16.20.13 gateway=\
172.16.20.1 netmask=24
add address=172.16.30.0/24 dns-server=172.16.20.15,172.16.30.1 gateway=\
172.16.30.1 netmask=24
set allow-remote-requests=yes
/ip firewall address-list
add address=151.105.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=5.23.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=5.44.240.0/21 comment=FINLAND list=CountryIPBlocks
add address=5.61.88.0/21 comment=FINLAND list=CountryIPBlocks
add address=5.83.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=5.104.80.0/21 comment=FINLAND list=CountryIPBlocks
add address=5.250.160.0/21 comment=FINLAND list=CountryIPBlocks
add address=31.7.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=31.15.120.0/21 comment=FINLAND list=CountryIPBlocks
add address=31.25.144.0/21 comment=FINLAND list=CountryIPBlocks
add address=31.47.64.0/21 comment=FINLAND list=CountryIPBlocks
add address=31.172.152.0/21 comment=FINLAND list=CountryIPBlocks
add address=31.187.84.0/22 comment=FINLAND list=CountryIPBlocks
add address=31.217.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.1.184.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.16.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=37.19.16.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.33.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=37.35.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=37.35.80.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.44.48.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.98.128.0/20 comment=FINLAND list=CountryIPBlocks
add address=37.114.80.0/21 comment=FINLAND list=CountryIPBlocks
add address=37.130.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=37.136.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=37.219.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=37.233.88.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.17.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.23.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=46.30.128.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.132.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=46.163.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=46.182.112.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.182.160.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.183.72.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.228.128.0/20 comment=FINLAND list=CountryIPBlocks
add address=46.231.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.254.96.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.254.208.0/21 comment=FINLAND list=CountryIPBlocks
add address=46.255.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=62.44.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=62.61.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=62.71.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=62.72.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.73.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.78.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.78.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=62.80.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.106.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.106.32.0/20 comment=FINLAND list=CountryIPBlocks
add address=62.106.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=62.113.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.121.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.142.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=62.145.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.148.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.148.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.165.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.165.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.176.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.183.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=62.197.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.204.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.216.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.220.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.236.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=62.237.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=62.240.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=62.241.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=62.248.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=77.72.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=77.86.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=77.91.208.0/21 comment=FINLAND list=CountryIPBlocks
add address=77.95.144.0/21 comment=FINLAND list=CountryIPBlocks
add address=77.95.240.0/21 comment=FINLAND list=CountryIPBlocks
add address=77.105.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=77.109.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=77.223.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=77.234.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=77.240.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=77.246.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=78.27.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=79.99.152.0/21 comment=FINLAND list=CountryIPBlocks
add address=79.133.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=79.134.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=79.141.144.0/20 comment=FINLAND list=CountryIPBlocks
add address=79.171.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=79.171.232.0/21 comment=FINLAND list=CountryIPBlocks
add address=80.64.0.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.66.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.69.160.0/21 comment=FINLAND list=CountryIPBlocks
add address=80.69.168.0/22 comment=FINLAND list=CountryIPBlocks
add address=80.69.172.0/22 comment=FINLAND list=CountryIPBlocks
add address=80.71.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.74.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.74.208.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.75.96.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.81.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.81.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.83.0.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.88.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.95.128.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.186.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=80.220.0.0/14 comment=FINLAND list=CountryIPBlocks
add address=80.242.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.246.144.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.246.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.247.240.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.248.96.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.248.112.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.248.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=80.248.240.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.16.64.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.17.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=81.17.200.0/21 comment=FINLAND list=CountryIPBlocks
add address=81.19.112.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.22.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.22.240.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.29.128.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.31.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.90.64.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.175.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=81.197.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=81.209.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=82.103.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=82.116.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.118.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.128.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=82.133.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=82.141.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=82.181.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=82.195.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.197.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.199.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.199.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=82.203.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=82.215.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.100.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=83.102.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=83.136.248.0/21 comment=FINLAND list=CountryIPBlocks
add address=83.145.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.146.128.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.146.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.148.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.150.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.216.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=83.245.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=84.20.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=84.34.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=84.230.0.0/15 comment=FINLAND list=CountryIPBlocks
add address=84.239.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=84.240.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=84.248.0.0/14 comment=FINLAND list=CountryIPBlocks
add address=84.253.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=85.23.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=85.29.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=85.76.0.0/14 comment=FINLAND list=CountryIPBlocks
add address=85.131.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=85.134.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=85.156.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=85.157.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=85.194.192.0/22 comment=FINLAND list=CountryIPBlocks
add address=85.194.204.0/22 comment=FINLAND list=CountryIPBlocks
add address=85.194.208.0/21 comment=FINLAND list=CountryIPBlocks
add address=85.194.216.0/22 comment=FINLAND list=CountryIPBlocks
add address=85.194.220.0/22 comment=FINLAND list=CountryIPBlocks
add address=85.194.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=85.194.232.0/24 comment=FINLAND list=CountryIPBlocks
add address=85.194.234.0/23 comment=FINLAND list=CountryIPBlocks
add address=85.194.236.0/23 comment=FINLAND list=CountryIPBlocks
add address=85.194.238.0/23 comment=FINLAND list=CountryIPBlocks
add address=85.217.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=86.50.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=86.60.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=86.114.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=86.115.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=87.92.0.0/14 comment=FINLAND list=CountryIPBlocks
add address=87.100.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=87.108.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=87.236.152.0/21 comment=FINLAND list=CountryIPBlocks
add address=87.236.168.0/21 comment=FINLAND list=CountryIPBlocks
add address=87.236.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=87.254.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=88.85.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=88.86.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=88.112.0.0/15 comment=FINLAND list=CountryIPBlocks
add address=88.114.0.0/15 comment=FINLAND list=CountryIPBlocks
add address=88.148.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=88.192.0.0/14 comment=FINLAND list=CountryIPBlocks
add address=89.17.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=89.18.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=89.27.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=89.106.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=89.166.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=89.190.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=89.236.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=89.250.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=91.105.248.0/21 comment=FINLAND list=CountryIPBlocks
add address=91.145.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=91.150.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=91.152.0.0/13 comment=FINLAND list=CountryIPBlocks
add address=91.190.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=92.240.152.0/21 comment=FINLAND list=CountryIPBlocks
add address=93.90.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=93.91.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=93.106.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=93.174.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=93.190.96.0/21 comment=FINLAND list=CountryIPBlocks
add address=93.191.120.0/21 comment=FINLAND list=CountryIPBlocks
add address=94.22.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=94.101.0.0/20 comment=FINLAND list=CountryIPBlocks
add address=94.126.160.0/21 comment=FINLAND list=CountryIPBlocks
add address=94.199.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=94.199.112.0/21 comment=FINLAND list=CountryIPBlocks
add address=94.237.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=95.130.24.0/21 comment=FINLAND list=CountryIPBlocks
add address=95.175.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=109.68.128.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.68.248.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.69.32.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.69.120.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.70.160.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.70.176.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.75.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.75.232.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.108.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=109.163.208.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.163.248.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.204.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=109.205.96.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.232.80.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.234.240.0/21 comment=FINLAND list=CountryIPBlocks
add address=109.240.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=139.97.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=146.66.24.0/21 comment=FINLAND list=CountryIPBlocks
add address=149.126.176.0/21 comment=FINLAND list=CountryIPBlocks
add address=149.154.120.0/21 comment=FINLAND list=CountryIPBlocks
add address=159.255.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=164.215.32.0/21 comment=FINLAND list=CountryIPBlocks
add address=176.72.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=176.93.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=178.16.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=178.21.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=178.55.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=178.75.128.0/18 comment=FINLAND list=CountryIPBlocks
add address=178.239.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=178.251.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=178.251.144.0/21 comment=FINLAND list=CountryIPBlocks
add address=178.251.152.0/21 comment=FINLAND list=CountryIPBlocks
add address=185.4.228.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.6.180.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.9.8.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.10.196.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.11.208.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.15.212.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.16.96.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.16.168.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.18.76.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.20.136.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.21.0.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.22.132.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.25.76.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.25.200.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.26.48.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.28.244.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.31.68.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.31.136.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.33.72.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.36.96.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.36.148.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.37.132.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.38.0.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.39.128.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.39.184.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.40.88.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.40.200.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.43.88.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.43.120.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.47.76.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.50.88.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.50.244.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.52.164.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.53.84.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.55.32.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.55.84.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.55.176.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.57.180.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.58.32.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.59.116.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.61.232.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.67.80.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.68.56.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.69.36.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.69.72.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.69.140.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.72.116.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.75.128.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.77.244.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.81.68.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.82.144.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.83.116.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.83.204.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.85.52.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.87.108.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.87.244.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.89.52.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.92.112.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.93.48.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.98.228.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.102.232.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.115.16.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.115.240.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.116.32.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.117.220.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.118.224.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.118.232.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.119.128.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.120.48.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.121.216.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.122.108.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.123.116.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.123.132.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.124.88.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.124.92.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.125.28.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.127.60.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.127.72.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.127.84.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.128.16.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.128.160.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.128.252.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.129.152.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.130.64.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.131.216.0/22 comment=FINLAND list=CountryIPBlocks
add address=185.132.104.0/22 comment=FINLAND list=CountryIPBlocks
add address=188.64.0.0/21 comment=FINLAND list=CountryIPBlocks
add address=188.65.136.0/21 comment=FINLAND list=CountryIPBlocks
add address=188.67.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=188.94.64.0/21 comment=FINLAND list=CountryIPBlocks
add address=188.117.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=188.123.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=188.127.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=188.238.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=192.77.120.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.89.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=192.102.18.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.102.20.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.102.24.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.102.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.102.66.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.102.68.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.102.72.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.102.80.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.107.200.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.107.208.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.107.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.126.1.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.126.2.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.126.4.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.126.8.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.126.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.126.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.126.64.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.130.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=192.136.71.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.136.72.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.136.80.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.136.96.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.136.100.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.136.102.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.163.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.163.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=192.163.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.175.32.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.45.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.194.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.64.0.0/15 comment=FINLAND list=CountryIPBlocks
add address=193.66.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.94.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.166.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.167.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.184.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.185.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.199.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.208.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.209.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.210.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.211.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=193.229.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=193.229.32.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.229.40.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.229.48.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.229.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.229.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=193.229.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=194.29.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=194.79.16.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.86.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.89.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.100.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=194.100.32.0/21 comment=FINLAND list=CountryIPBlocks
add address=194.100.40.0/21 comment=FINLAND list=CountryIPBlocks
add address=194.100.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=194.100.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=194.100.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=194.110.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=194.111.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.112.0.0/20 comment=FINLAND list=CountryIPBlocks
add address=194.136.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.137.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.142.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.157.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.188.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.197.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.211.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.215.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.240.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.241.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.251.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=194.252.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.10.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.10.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.16.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.74.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.94.96.0/21 comment=FINLAND list=CountryIPBlocks
add address=195.94.104.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.134.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.148.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.156.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.165.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.170.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.197.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.218.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.236.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.237.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=195.238.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.244.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.255.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.255.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.255.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.255.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=195.255.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=212.16.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.17.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.38.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.50.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.50.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.54.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.63.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.66.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.68.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.83.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.86.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.90.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.94.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.116.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=212.146.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=212.149.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=212.149.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=212.182.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=212.213.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=212.226.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=212.246.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=213.28.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=213.130.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.138.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.139.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.140.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.141.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.143.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.145.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.157.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.161.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.169.0.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.173.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.185.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.186.224.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.192.128.0/18 comment=FINLAND list=CountryIPBlocks
add address=213.204.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=213.214.128.0/18 comment=FINLAND list=CountryIPBlocks
add address=213.216.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=213.243.128.0/18 comment=FINLAND list=CountryIPBlocks
add address=213.250.64.0/18 comment=FINLAND list=CountryIPBlocks
add address=213.255.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=217.24.96.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.25.96.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.29.224.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.30.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.64.32.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.64.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.69.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.77.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.78.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.78.208.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.112.192.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.112.240.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.116.160.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.119.32.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.140.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=217.149.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=217.152.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=217.169.64.0/20 comment=FINLAND list=CountryIPBlocks
add address=46.173.224.0/20 comment=FINLAND list=CountryIPBlocks
add address=81.20.224.0/20 comment=FINLAND list=CountryIPBlocks
add address=82.130.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=83.142.72.0/21 comment=FINLAND list=CountryIPBlocks
add address=83.143.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=83.143.88.0/21 comment=FINLAND list=CountryIPBlocks
add address=83.143.216.0/21 comment=FINLAND list=CountryIPBlocks
add address=84.234.64.0/20 comment=FINLAND list=CountryIPBlocks
add address=85.188.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=87.239.120.0/21 comment=FINLAND list=CountryIPBlocks
add address=89.200.192.0/21 comment=FINLAND list=CountryIPBlocks
add address=91.90.48.0/21 comment=FINLAND list=CountryIPBlocks
add address=91.123.128.0/20 comment=FINLAND list=CountryIPBlocks
add address=91.194.20.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.197.84.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.197.208.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.198.120.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.199.148.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.202.112.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.209.29.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.213.97.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.213.161.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.214.164.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.215.132.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.216.77.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.216.136.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.217.116.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.217.211.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.217.248.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.217.252.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.219.172.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.220.241.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.221.66.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.221.238.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.222.188.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.223.107.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.223.116.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.224.4.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.224.88.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.225.68.0/22 comment=FINLAND list=CountryIPBlocks
add address=91.227.187.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.227.192.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.229.137.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.229.138.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.230.4.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.232.154.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.232.156.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.233.116.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.233.125.0/24 comment=FINLAND list=CountryIPBlocks
add address=91.234.204.0/23 comment=FINLAND list=CountryIPBlocks
add address=91.237.151.0/24 comment=FINLAND list=CountryIPBlocks
add address=128.214.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.188.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.230.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.231.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.232.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.233.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=130.234.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=131.160.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=131.177.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=131.207.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=131.228.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=132.155.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=132.171.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=134.37.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=137.33.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=137.96.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=137.163.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=138.216.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=138.249.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=139.66.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=139.74.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=139.123.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=139.157.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=140.151.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=141.172.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=141.192.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=141.208.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=143.51.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=143.51.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=144.4.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=145.247.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=146.81.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=146.119.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=146.161.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=146.211.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=147.243.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=149.197.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=153.1.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=156.10.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.24.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.94.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.124.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.129.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.144.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=157.200.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=158.90.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=158.90.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=158.127.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=158.131.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=158.233.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=159.152.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=160.71.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=161.41.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=164.5.0.0/17 comment=FINLAND list=CountryIPBlocks
add address=164.5.128.0/19 comment=FINLAND list=CountryIPBlocks
add address=164.5.160.0/19 comment=FINLAND list=CountryIPBlocks
add address=164.5.192.0/18 comment=FINLAND list=CountryIPBlocks
add address=164.13.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=164.141.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=178.213.232.0/21 comment=FINLAND list=CountryIPBlocks
add address=178.217.128.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.26.105.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.106.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.107.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.108.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.109.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.111.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.112.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.113.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.114.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.115.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.116.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.117.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.118.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.119.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.120.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.121.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.122.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.123.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.124.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.125.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.126.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.127.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.128.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.133.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.134.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.26.135.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.34.179.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.40.72.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.40.228.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.49.0.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.49.16.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.49.24.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.49.28.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.49.29.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.49.30.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.49.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.49.64.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.49.72.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.49.74.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.49.75.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.49.76.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.49.80.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.49.96.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.49.128.0/17 comment=FINLAND list=CountryIPBlocks
add address=192.58.30.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.58.41.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.58.42.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.58.44.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.58.48.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.58.64.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.58.80.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.58.88.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.81.123.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.81.160.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.83.0.0/18 comment=FINLAND list=CountryIPBlocks
add address=192.83.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=192.83.96.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.83.100.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.88.86.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.92.116.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.98.0.0/16 comment=FINLAND list=CountryIPBlocks
add address=192.100.102.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.100.104.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.100.112.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.100.128.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.100.132.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.101.192.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.102.64.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.103.85.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.103.86.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.103.88.0/21 comment=FINLAND list=CountryIPBlocks
add address=192.103.96.0/20 comment=FINLAND list=CountryIPBlocks
add address=192.103.112.0/22 comment=FINLAND list=CountryIPBlocks
add address=192.103.116.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.112.204.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.131.96.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.133.110.0/23 comment=FINLAND list=CountryIPBlocks
add address=192.136.9.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.146.152.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.147.215.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.147.216.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.149.5.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.152.68.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.159.70.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.159.122.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.33.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.34.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.35.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.36.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.44.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.46.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.175.47.0/24 comment=FINLAND list=CountryIPBlocks
add address=192.203.108.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.0.164.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.19.136.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.24.64.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.28.89.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.28.203.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.34.40.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.93.132.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.93.136.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.104.38.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.104.188.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.104.196.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.105.76.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.105.97.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.105.123.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.105.160.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.106.8.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.110.32.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.110.64.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.110.108.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.110.110.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.110.224.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.111.64.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.111.93.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.111.118.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.138.126.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.138.200.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.142.1.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.2.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.5.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.7.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.8.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.142.16.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.142.23.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.24.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.142.26.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.50.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.51.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.55.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.64.0/19 comment=FINLAND list=CountryIPBlocks
add address=193.142.96.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.98.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.99.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.101.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.102.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.120.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.121.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.122.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.123.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.136.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.142.150.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.176.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.142.184.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.142.204.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.142.235.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.236.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.142.240.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.247.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.251.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.142.252.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.4.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.8.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.19.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.32.0/19 comment=FINLAND list=CountryIPBlocks
add address=193.143.70.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.73.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.74.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.79.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.80.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.81.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.82.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.83.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.84.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.86.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.87.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.88.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.89.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.91.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.93.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.94.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.95.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.99.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.100.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.143.104.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.112.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.143.116.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.118.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.124.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.125.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.126.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.127.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.128.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.136.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.143.140.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.142.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.144.0/20 comment=FINLAND list=CountryIPBlocks
add address=193.143.160.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.161.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.162.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.143.164.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.143.168.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.176.0/20 comment=FINLAND list=CountryIPBlocks
add address=193.143.192.0/19 comment=FINLAND list=CountryIPBlocks
add address=193.143.225.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.228.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.229.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.230.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.232.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.240.0/21 comment=FINLAND list=CountryIPBlocks
add address=193.143.253.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.143.254.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.169.84.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.169.100.0/23 comment=FINLAND list=CountryIPBlocks
add address=193.178.133.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.201.144.128/25 comment=FINLAND list=CountryIPBlocks
add address=193.201.145.0/25 comment=FINLAND list=CountryIPBlocks
add address=193.222.133.0/24 comment=FINLAND list=CountryIPBlocks
add address=193.238.4.0/22 comment=FINLAND list=CountryIPBlocks
add address=193.242.126.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.0.80.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.8.226.0/23 comment=FINLAND list=CountryIPBlocks
add address=194.28.0.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.41.16.0/20 comment=FINLAND list=CountryIPBlocks
add address=194.42.56.0/21 comment=FINLAND list=CountryIPBlocks
add address=194.50.168.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.23.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.24.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.31.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.32.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.110.36.0/23 comment=FINLAND list=CountryIPBlocks
add address=194.110.38.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.39.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.40.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.110.44.0/23 comment=FINLAND list=CountryIPBlocks
add address=194.110.46.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.47.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.62.0/23 comment=FINLAND list=CountryIPBlocks
add address=194.110.142.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.110.224.0/21 comment=FINLAND list=CountryIPBlocks
add address=194.110.232.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.126.212.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.145.32.0/20 comment=FINLAND list=CountryIPBlocks
add address=194.145.48.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.145.52.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.153.159.64/26 comment=FINLAND list=CountryIPBlocks
add address=194.176.103.0/24 comment=FINLAND list=CountryIPBlocks
add address=194.187.212.0/22 comment=FINLAND list=CountryIPBlocks
add address=194.187.232.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.8.54.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.8.60.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.14.15.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.20.16.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.20.116.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.20.149.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.60.81.128/26 comment=FINLAND list=CountryIPBlocks
add address=195.60.90.0/25 comment=FINLAND list=CountryIPBlocks
add address=195.60.252.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.78.70.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.95.208.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.138.213.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.140.192.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.149.83.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.191.122.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.200.68.0/23 comment=FINLAND list=CountryIPBlocks
add address=195.211.16.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.226.202.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.234.135.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.234.142.0/24 comment=FINLAND list=CountryIPBlocks
add address=195.234.196.0/22 comment=FINLAND list=CountryIPBlocks
add address=195.248.86.0/24 comment=FINLAND list=CountryIPBlocks
add address=217.71.144.0/20 comment=FINLAND list=CountryIPBlocks
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept established, related" \
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=drop chain=input comment="Drop all from WAN" in-interface=WAN
"Drop traffic from 172.16.1.0/24 to Plex" dst-address=172.16.20.14 \
dst-port=32400 protocol=tcp src-address=172.16.1.0/24
"Drop traffic from 172.16.1.0/24 to Jellyfin" dst-address=172.16.20.16 \
dst-port=8096 protocol=tcp src-address=172.16.1.0/24
add action=fasttrack-connection chain=forward comment=Fasttrack \
add action=accept chain=forward comment="Accept established, related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface=WAN
add action=masquerade chain=srcnat out-interface=WAN
add action=dst-nat chain=dstnat comment=RD disabled=yes dst-port=3389 \
in-interface=ether1 protocol=tcp src-address-list=CountryIPBlocks \
to-addresses=172.16.20.12 to-ports=3389
add action=dst-nat chain=dstnat comment=HTTP/HTTPS dst-port=80,443 \
in-interface=WAN protocol=tcp to-addresses=172.16.20.18
add action=dst-nat chain=dstnat comment=Plex dst-port=11586 in-interface=WAN \
protocol=tcp to-addresses=172.16.20.14 to-ports=32400
add action=dst-nat chain=dstnat comment="OpenVPN (tcp)" disabled=yes \
dst-port=1194 in-interface=ether1 protocol=tcp to-addresses=172.16.20.16 \
to-ports=1194
add action=dst-nat chain=dstnat comment="OpenVPN (udp)" disabled=yes \
dst-port=1194 in-interface=ether1 protocol=udp to-addresses=172.16.20.16 \
to-ports=1194
add action=dst-nat chain=dstnat comment=SSH dst-port=22 in-interface=WAN \
protocol=tcp src-address-list=CountryIPBlocks to-addresses=172.16.20.18 \
to-ports=22
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/lcd pin
set pin-number=xxxx
/routing filter
add action=accept chain=only-private prefix=10.0.0.0/8 prefix-length=8-32
add action=accept chain=only-private prefix=172.16.0.0/12 prefix-length=12-32
add action=accept chain=only-private prefix=192.168.0.0/16 prefix-length=\
16-32
add action=discard chain=only-private prefix=0.0.0.0/0 prefix-length=0-32
/routing ospf network
add area=backbone network=172.16.254.0/30
/system clock
set time-zone-name=Europe/Helsinki
/system identity
set name=router1
/system logging
add topics=dhcp
/system ntp client
set enabled=yes primary-ntp=194.157.230.37 secondary-ntp=185.47.76.21
/system scheduler
add interval=15m name=DNStunnel on-event="/system script run dnstunnelupdate" \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=apr/30/2018 start-time=17:05:19
/system script
add dont-require-permissions=no name=dnstunnelupdate owner=xxx policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="#\
\_How to use:\r\
\n# Comment a tunnel something like the line below (no need for the #)\r\
\n# LocalDNS:somedomain.com RemoteDNS:someotherdomain.com\r\
\n# You don't have to use both LocalDNS and RemoteDNS, they're optional, i\
f they're not found in a comment the tunnel is skipped\r\
\n# You can choose to only use LocalDNS or RemoteDNS, or both.\r\
\n# Schedule this script to run once a minute\r\
\n# See it resolve and fix all your tunnels\r\
\n\r\
\n\r\
\n:local LocalDNSPrefix \"LocalDNS:\"\r\
\n:local RemoteDNSPrefix \"RemoteDNS:\"\r\
\n\r\
\n:foreach i in=[/interface eoip find] do={\r\
\n :local ifacename [/interface eoip get \$i name]\r\
\n :local comment [/interface eoip get \$i comment]\r\
\n\r\
\n :local localdnsnamepos [:find \$comment \$LocalDNSPrefix -1]\r\
\n if ([:len \$localdnsnamepos] > 0) do={\r\
\n :local start (\$localdnsnamepos + [:len \$LocalDNSPrefix])\r\
\n :local end ([:find \$comment \" \" (\$localdnsnamepos + [:len \$\
LocalDNSPrefix])])\r\
\n if ([:len \$end] = 0) do={\r\
\n :set end [:len \$comment]\r\
\n }\r\
\n :local dnsname [:pick \$comment \$start \$end]\r\
\n :local currentip [/interface eoip get \$i local-address]\r\
\n :local newip \"\"\r\
\n :do { :set newip [:resolve \$dnsname] } on-error={}\r\
\n if ([:len \$newip] <= 0) do={\r\
\n :log info \"Skipping update on tunnel \$ifacename, nxdomain\
\"\r\
\n } else={\r\
\n if (\$currentip != \$newip) do={\r\
\n /interface eoip set \$i local-address \$newip\r\
\n :log info \"Updated tunnel \$ifacename with local-address\
\_\$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n \r\
\n :local remotednsnamepos [:find \$comment \$RemoteDNSPrefix -1]\r\
\n if ([:len \$remotednsnamepos] > 0) do={\r\
\n :local start (\$remotednsnamepos + [:len \$RemoteDNSPrefix])\r\
\n :local end ([:find \$comment \" \" (\$remotednsnamepos + [:len \
\$RemoteDNSPrefix])])\r\
\n }\r\
\n :local currentip [/interface eoip get \$i remote-address]\r\
\"\r\
\n } else={\r\
\n /interface eoip set \$i remote-address \$newip\r\
\n :log info \"Updated tunnel \$ifacename with remote-addres\
s \$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n}\r\
\n\r\
\n:foreach i in=[/interface gre find] do={\r\
\n :local ifacename [/interface gre get \$i name]\r\
\n :local comment [/interface gre get \$i comment]\r\
\n\r\
\n }\r\
\n :local currentip [/interface gre get \$i local-address]\r\
\"\r\
\n } else={\r\
\n /interface gre set \$i local-address \$newip\r\
\_\$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n \r\
\n }\r\
\n :local currentip [/interface gre get \$i remote-address]\r\
\"\r\
\n } else={\r\
\n /interface gre set \$i remote-address \$newip\r\
s \$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n}\r\
\n\r\
\n:foreach i in=[/interface ipip find] do={\r\
\n :local ifacename [/interface ipip get \$i name]\r\
\n :local comment [/interface ipip get \$i comment]\r\
\n\r\
\n }\r\
\n :local currentip [/interface ipip get \$i local-address]\r\
\"\r\
\n } else={\r\
\n /interface ipip set \$i local-address \$newip\r\
\_\$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n \r\
\n }\r\
\n :local currentip [/interface ipip get \$i remote-address]\r\
\"\r\
\n } else={\r\
\n /interface ipip set \$i remote-address \$newip\r\
s \$newip\"\r\
\n }\r\
\n }\r\
\n }\r\
\n}"
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
add allow-address=172.16.10.0/24
add allow-address=172.16.20.0/24
add allow-address=172.16.1.0/24
/tool graphing resource
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Here is one occasion when lease does expire
nov/23 00:11:31 dhcp,critical,error dhcp-client on WAN lost IP address 83.xx.160.xx - lease expired
nov/23 00:11:31 dhcp,debug,state dhcp-client on WAN entering <selecting...> state
nov/23 00:11:32 interface,info gre-tunnel1 link down
nov/23 00:11:32 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:32 dhcp,debug,packet flags = broadcast
nov/23 00:11:32 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:32 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:32 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:32 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:32 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:32 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:32 route,ospf,info OSPFv2 neighbor 172.16.1.1: state change from Full to Down
nov/23 00:11:33 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:33 dhcp,debug,packet secs = 2
nov/23 00:11:33 dhcp,debug,packet flags = broadcast
nov/23 00:11:33 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:33 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:33 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:33 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:33 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:33 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:35 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:35 dhcp,debug,packet secs = 3
nov/23 00:11:35 dhcp,debug,packet flags = broadcast
nov/23 00:11:35 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:35 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:35 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:35 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:35 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:35 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:36 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:36 dhcp,debug,packet secs = 4
nov/23 00:11:36 dhcp,debug,packet flags = broadcast
nov/23 00:11:36 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:36 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:36 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:36 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:36 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:36 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:38 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:38 dhcp,debug,packet secs = 6
nov/23 00:11:38 dhcp,debug,packet flags = broadcast
nov/23 00:11:38 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:38 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:38 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:38 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:38 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:38 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:43 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:43 dhcp,debug,packet secs = 11
nov/23 00:11:43 dhcp,debug,packet flags = broadcast
nov/23 00:11:43 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:43 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:43 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:43 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:43 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:43 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:46 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:46 dhcp,debug,packet secs = 15
nov/23 00:11:46 dhcp,debug,packet flags = broadcast
nov/23 00:11:46 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:46 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:46 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:46 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:46 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:46 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:50 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:50 dhcp,debug,packet secs = 18
nov/23 00:11:50 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:50 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:50 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:50 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:50 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:50 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:53 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:53 dhcp,debug,packet secs = 22
nov/23 00:11:53 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:53 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:53 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:53 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:53 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:53 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:11:59 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:11:59 dhcp,debug,packet secs = 28
nov/23 00:11:59 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:11:59 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:11:59 dhcp,debug,packet Msg-Type = discover
nov/23 00:11:59 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:11:59 dhcp,debug,packet Host-Name = "router1"
nov/23 00:11:59 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:01 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:01 dhcp,debug,packet secs = 29
nov/23 00:12:01 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:01 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:01 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:01 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:01 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:01 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:05 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:05 dhcp,debug,packet secs = 33
nov/23 00:12:05 dhcp,debug,packet flags = broadcast
nov/23 00:12:05 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:05 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:05 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:05 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:05 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:05 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:10 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:10 dhcp,debug,packet secs = 38
nov/23 00:12:10 dhcp,debug,packet flags = broadcast
nov/23 00:12:10 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:10 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:10 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:10 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:10 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:10 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:11 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:11 dhcp,debug,packet secs = 39
nov/23 00:12:11 dhcp,debug,packet flags = broadcast
nov/23 00:12:11 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:11 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:11 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:11 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:11 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:11 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:17 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:17 dhcp,debug,packet secs = 46
nov/23 00:12:17 dhcp,debug,packet flags = broadcast
nov/23 00:12:17 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:17 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:17 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:17 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:17 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:17 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:19 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:19 dhcp,debug,packet secs = 47
nov/23 00:12:19 dhcp,debug,packet flags = broadcast
nov/23 00:12:19 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:19 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:19 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:19 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:19 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:19 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:25 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:25 dhcp,debug,packet secs = 53
nov/23 00:12:25 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:25 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:25 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:25 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:25 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:25 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:30 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:30 dhcp,debug,packet secs = 59
nov/23 00:12:30 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:30 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:30 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:30 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:30 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:30 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:33 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:33 dhcp,debug,packet secs = 61
nov/23 00:12:33 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:33 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:33 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:33 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:33 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:33 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:34 dhcp,debug,packet dhcp-client on WAN sending discover with id 2269434290 to 255.255.255.255
nov/23 00:12:34 dhcp,debug,packet secs = 63
nov/23 00:12:34 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:34 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:34 dhcp,debug,packet Msg-Type = discover
nov/23 00:12:34 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 00:12:34 dhcp,debug,packet Host-Name = "router1"
nov/23 00:12:34 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 00:12:34 dhcp,debug,packet dhcp-client on WAN received offer with id 2269434290 from 83.xx.160.1
nov/23 00:12:34 dhcp,debug,packet hops = 1
nov/23 00:12:34 dhcp,debug,packet yiaddr = 83.xx.160.xx
nov/23 00:12:34 dhcp,debug,packet Msg-Type = offer
nov/23 00:12:34 dhcp,debug,packet Server-Id = 10.77.77.10
nov/23 00:12:34 dhcp,debug,packet Address-Time = 7200
nov/23 00:12:34 dhcp,debug,packet Subnet-Mask = 255.255.252.0
nov/23 00:12:34 dhcp,debug,packet Router = 83.xx.160.1
nov/23 00:12:34 dhcp,debug,packet Domain-Server = 46.163.192.130,46.163.192.140
nov/23 00:12:34 dhcp,debug,state dhcp-client on WAN entering <requesting...> state
nov/23 00:12:34 dhcp,debug,packet dhcp-client on WAN sending request with id 2269434290 to 255.255.255.255
nov/23 00:12:34 dhcp,debug,packet Msg-Type = request
nov/23 00:12:34 dhcp,debug,packet Address-Request = 83.xx.160.xx
nov/23 00:12:34 dhcp,debug,packet Server-Id = 10.77.77.11
nov/23 00:12:35 dhcp,debug,packet dhcp-client on WAN received ack with id 2269434290 from 83.xx.160.1
nov/23 00:12:35 dhcp,debug,packet hops = 1
nov/23 00:12:35 dhcp,debug,packet secs = 63
nov/23 00:12:35 dhcp,debug,packet ciaddr = 0.0.0.0
nov/23 00:12:35 dhcp,debug,packet yiaddr = 83.xx.160.xx
nov/23 00:12:35 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 00:12:35 dhcp,debug,packet Msg-Type = ack
nov/23 00:12:35 dhcp,debug,packet Server-Id = 10.77.77.10
nov/23 00:12:35 dhcp,debug,packet Address-Time = 7200
nov/23 00:12:35 dhcp,debug,packet Subnet-Mask = 255.255.252.0
nov/23 00:12:35 dhcp,debug,packet Router = 83.xx.160.1
nov/23 00:12:35 dhcp,debug,packet Domain-Server = 46.163.192.130,46.163.192.140
nov/23 00:12:35 dhcp,info dhcp-client on WAN got IP address 83.xx.160.xx
nov/23 00:12:35 dhcp,debug,state dhcp-client on WAN entering <bound> state
One occasion where it actually does get a answer after several attempts from 10.77.77.10 before the state changes to rebinding
nov/23 01:12:35 dhcp,debug,state dhcp-client on WAN entering <renewing...> state
nov/23 01:12:35 dhcp,debug,packet dhcp-client on WAN sending request with id 2269434290 to 10.77.77.10
nov/23 01:12:35 dhcp,debug,packet ciaddr = 83.xx.160.xx
nov/23 01:12:35 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 01:12:35 dhcp,debug,packet Msg-Type = request
nov/23 01:12:35 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 01:12:35 dhcp,debug,packet Host-Name = "router1"
nov/23 01:12:35 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 01:46:19 dhcp,debug,packet dhcp-client on WAN sending request with id 2269434290 to 10.77.77.10
nov/23 01:46:19 dhcp,debug,packet secs = 2024
nov/23 01:46:19 dhcp,debug,packet ciaddr = 83.xx.160.xx
nov/23 01:46:19 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 01:46:19 dhcp,debug,packet Msg-Type = request
nov/23 01:46:19 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 01:46:19 dhcp,debug,packet Host-Name = "router1"
nov/23 01:46:19 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
the same attempt multiple times before the successful one
nov/23 01:57:08 dhcp,debug,packet dhcp-client on WAN sending request with id 2269434290 to 10.77.77.10
nov/23 01:57:08 dhcp,debug,packet secs = 2673
nov/23 01:57:08 dhcp,debug,packet ciaddr = 83.xx.160.xx
nov/23 01:57:08 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
nov/23 01:57:08 dhcp,debug,packet Msg-Type = request
nov/23 01:57:08 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
nov/23 01:57:08 dhcp,debug,packet Host-Name = "router1"
nov/23 01:57:08 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
nov/23 01:57:08 dhcp,debug,packet dhcp-client on WAN received ack with id 2269434290 from 10.77.77.10
nov/23 01:57:08 dhcp,debug,packet yiaddr = 83.xx.160.xx
nov/23 01:57:08 dhcp,debug,packet Msg-Type = ack
nov/23 01:57:08 dhcp,debug,packet Server-Id = 10.77.77.10
nov/23 01:57:08 dhcp,debug,packet Address-Time = 7200
nov/23 01:57:08 dhcp,debug,packet Subnet-Mask = 255.255.252.0
nov/23 01:57:08 dhcp,debug,packet Router = 83.xx.160.1
nov/23 01:57:08 dhcp,debug,packet Domain-Server = 46.163.192.130,46.163.192.140
nov/23 01:57:08 dhcp,debug,state dhcp-client on WAN entering <bound> state
And one occasion when it succeeds when it is in rebinding state
00:34:33 dhcp,debug,packet dhcp-client on WAN sending request with id 2374689444 to 10.77.77.10
00:34:33 dhcp,debug,packet secs = 2698
00:34:33 dhcp,debug,packet ciaddr = 83.xx.160.xx
00:34:33 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
00:34:33 dhcp,debug,packet Msg-Type = request
00:34:33 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
00:34:33 dhcp,debug,packet Host-Name = "router1"
00:34:33 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
00:34:34 dhcp,debug,state dhcp-client on WAN entering <rebinding...> state
00:34:34 dhcp,debug,packet dhcp-client on WAN sending request with id 2374689444 to 255.255.255.255
00:34:34 dhcp,debug,packet ciaddr = 83.xx.160.xx
00:34:34 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
00:34:34 dhcp,debug,packet Msg-Type = request
00:34:34 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
00:34:34 dhcp,debug,packet Host-Name = "router1"
00:34:34 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
multiple attempts again before a successful one
00:45:49 dhcp,debug,packet dhcp-client on WAN sending request with id 2374689444 to 255.255.255.255
00:45:49 dhcp,debug,packet secs = 675
00:45:49 dhcp,debug,packet ciaddr = 83.xx.160.xx
00:45:49 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
00:45:49 dhcp,debug,packet Msg-Type = request
00:45:49 dhcp,debug,packet Parameter-List = Subnet-Mask,Classless-Route,Router,Static-Route,Domain-Server,NTP-Server,CAPWAP-Server,Vendor-Specific
00:45:49 dhcp,debug,packet Host-Name = "router1"
00:45:49 dhcp,debug,packet Client-Id = 01-6C-3B-6B-28-85-C1
00:45:50 dhcp,debug,packet dhcp-client on WAN received ack with id 2374689444 from 83.xx.160.1
00:45:50 dhcp,debug,packet hops = 1
00:45:50 dhcp,debug,packet secs = 675
00:45:50 dhcp,debug,packet ciaddr = 83.xx.160.xx
00:45:50 dhcp,debug,packet yiaddr = 83.xx.160.xx
00:45:50 dhcp,debug,packet chaddr = 6C:3B:6B:28:85:C1
00:45:50 dhcp,debug,packet Msg-Type = ack
00:45:50 dhcp,debug,packet Server-Id = 10.77.77.10
00:45:50 dhcp,debug,packet Address-Time = 7200
00:45:50 dhcp,debug,packet Subnet-Mask = 255.255.252.0
00:45:50 dhcp,debug,packet Router = 83.xx.160.1
00:45:50 dhcp,debug,packet Domain-Server = 46.163.192.130,46.163.192.140
00:45:50 dhcp,debug,state dhcp-client on WAN entering <bound> state
