DHCP-Client : Lease stopped locally problem.
Hi, got some problems with my ZTE MF821D 4G Dongle. My CRS125 recognizes the dongle as an LTE device, and adds the interface. The ZTF got an web-interface for pin-input etc, on adress 192.168.0.1 (my local LAN is on 192.168.1.1) and I can reach this web-interface from my LAN. I also added an DHCP-Client to the LTE interface, as the ZTF has built in DHCP-server. I also added a masqurade rule, to allow internet access from LAN, in IP-Routes the gateway shows as reachable, and DHCP-Client shows up as “bound” with an assigned ip 192.168.0.100. Until this point, everything looks good.
I then have a script set-up for WAN failover. I used the one provided here : http://wiki.mikrotik.com/wiki/Failover_Scripting
(I tried it with Android yesterday, and it worked like a charm).
Once i plug out my primary-wan cable, it increases the primary-wan distance, and decreases the failover-wan (4g) route. Then the problem starts, my log shows this :
If I go to DHCP-Client now, it shows “bound”, “searching”, “bound” and so on.. Once I plug in my primary-wan cable again, thing settles. The LTE interface is no longer visible, and I have to re-plug it to the USB to show it again.
System information :
Dongle : ZTF MF821D (latest fw)
Router : CRS125
ROs : 6.23
