DHCP Client not responding to 'DHCP Offer' - stuck in 'searching' status
Hello all,
I’m relatively new to RouterOS, and I’ve got a problem with some 951G RouterBOARDS that I can’t solve.
My DrayTek 2710 ADSL router is operating as an AP and has a DHCP Server offering IP addresses over WiFi. I want to connect an RB (RouterBOARD 951G 2HnD) to this over the WLAN so I can plug in some wired ethernet devices in another part of the house.
I have put a DHCP Client on the RB WLAN (station mode) and I cannot pick up an IP address. The RB WLAN connects to ess, but the DHCP Client is stuck in ‘searching’. If I configure the WLAN to have a manual IP address it works OK, so I think that proves that there is nothing wrong with Layer 1/2. My other RB has identical problems. All other WiFi devices in the house have no problems (HP laptops, iPad, Android phones, etc.).
I tried setting up an AP on one of my RouterBOARDs and then I could use DHCP Client on the other one to get an IP address. So, I’m thinking I have an incompatibility between my DrayTek AP DHCP Server and RouterBOARD Station DHCP Client, - over the WLAN only. If I connect the DrayTek and RouterBOARD using wired connections, then it works OK.
To see if the problem is DrayTek or MikroTik, I ran a sniffer on another PC to see what broadcast packets were exchanged. I get:
 Time        Source        Destination       Port   Protocol   Length   Info
 27.458693   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 27.561175   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 28.484052   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 28.487481   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 31.042734   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 31.046145   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 32.273626   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 32.277059   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 34.216854   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 34.220197   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 40.053550   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 40.056889   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 44.354222   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 44.357576   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 46.709244   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 46.712898   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
 52.750600   0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0xc2fe3c0f
 52.753866   192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0xc2fe3c0f
Why do the RouterBOARDs not send out a ‘DHCP Request’ - the normal response to a ‘DHCP Offer’?
By the way, I did try running the ROS sniffer on the WLAN port on the RB, but it was useless - didn’t see any DHCP packets at all - just lots of Beacons and a tiny number of Data packets with MAC addresses I didn’t recognise - sorry, I’m pretty clueless about WLAN sniffing.
Here is the normal response I expect (got by getting one RB to connect to the AP of the other one - with similar security, etc., compared with the DrayTek AP):
 0.000000    0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Discover - Transaction ID 0x37cb4889
 0.538204    192.168.1.1   255.255.255.255   68     DHCP       342      DHCP Offer    - Transaction ID 0x37cb4889
 0.542769    0.0.0.0       255.255.255.255   67     DHCP       342      DHCP Request  - Transaction ID 0x37cb4889
 0.546100    192.168.1.1   255.255.255.255   68     DHCP       342      DHCP ACK      - Transaction ID 0x37cb4889
So, the usual RB DHCP Client operation is to send out a ‘DHCP Request’ 4 ms after the ‘DHCP Offer’ broadcast. Why is this not happening when the DrayTek broadcasts the ‘DHCP Offer’? I’ve looked at every bit in the header of a RB-issued ‘DHCP Offer’ and compared it with the header of the DrayTek-issued ‘DHCP Offer’. They are identical (apart from obvious things like Source MAC Addresses, Transaction IDs, and slightly different Parameter Request Lists).
So how does the RB recognise that one of the offers is from a DrayTek and then refuse to proceed any further in the transaction?
I’ve done the usual diagnostic things - rebooted DrayTek and RBs several times, put the latest firmware on everything, set both RBs back to factory settings (with no config) and just configured the minimum number of settings on the RBs to isolate the problem. I’ve spent half a day on this now, and don’t think I’ll make any more progress without some assistance from a grown up!
Help!
Paul.
It’s the OP again.
I got hold of another DrayTek ADSL router - a 2820n. With no change to the RouterBOARDs’ configuration, they work fine when getting a DHCP IP address from this router. I think that probably puts MikroTik in the clear!
I think I must have a dodgy DrayTek 2710. Although I could not see anything wrong with the ‘DHCP Offer’ packet that was turned down by the RBs.
If I find out any more I’ll post it here.
Paul
