DHCP client script
Hello.
I’m trying to get on via DHCP default route with comment and with dynamic gateway and make another route (eg to 1 IP of yandex only from GW of ISP-1 (ISP-1 is main internet and i have ISP-2 as reserved…
whats wrong with script of DHCPClient?
:local rmark "ISP-1"
:local count [/ip route print count-only where comment="ISP-1"]
:if ($bound=1) do={
:if ($count = 0) do={
/ip route add gateway=$"gateway-address" comment="ISP-1" distance=1
} else={
:if ($count = 1) do={
:local test [/ip route find where comment="ISP-1"]
:if ([/ip route get $test gateway] != $"gateway-address") do={
/ip route set $test gateway=$"gateway-address"
} else={
:error "Multiple routes found"
} else={
/ip route remove [find comment="ISP-1"]
Thats code is works well, but without adding additional route with a comment, but
:if ($bound=1) do={
} else={
} else={
} else={
:local rmark "YANDEX"
:local count2 [/ip route print count-only where comment="YNDX_CHK"]
:if ($bound=1) do={
:if ($count2 = 0) do={
/ip route add comment=YNDX_CHK distance=1 dst-address=77.88.55.242/32 gateway=$"gateway-address"
} else={
:if ($count2 = 1) do={
:local pingchk [/ip route find where comment="YNDX_CHK""]
:if ([/ip route get $pingchk gateway] != $"gateway-address") do={
/ip route set $pingchk gateway=$"gateway-address"
} else={
:error "Multiple YANDX check routes found"
} else={
/ip route remove [find comment="YNDX_CHK"]
Thats script doesnt work at all
Thats only adds default route with ISP-1 comment
:if ($bound=1) do={
} else={
} else={
} else={
:local yndxping [/ip route find where comment="YNDX_CHK"]
:if ([/ip route get $yndxping gateway] != $"gateway-address") do={
/ip route set $yndxping gateway=$"gateway-address"
} else={
:error "Multiple Yandex check found"
} else={
