dhcp client searching...
Hi, trying to figure out if this routerboard hEX s is defective or not.
I have reset device configuration to factory defaults current firmware is 6.44.1.
ether1 will not pull ip address via dhcp, other devices pull addresses via dhcp from the same switch hEX is connected to.
I believe ether1 dhcp is suppose to work right out of the box. I can login without issue using default login.
Is there a way to test ether1?
