Good evening! I was trying to set up CAPsMAN on Router MikroTik with RouterOS 7.14.3 and I need to get gateway address from DHCP-Client with interface bridge. So when I was trying to add a new DHCP Client for interfface: bridge, it just shows me status searching…
Logs are not showing any error, just loop messages of sending discover by dhcp-client.
Here is my config:
# 2024-05-30 16:24:11 by RouterOS 7.14.3
# software id = 62SF-2GZX
# model = D53G-5HacD2HnD
add admin-mac=2C:C8:1B:BC:24:1E auto-mac=no comment=defconf name=bridge
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" nr-band="" sms-read=no
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=5ghz-ac disabled=no frequency=5540 name=5G-AC skip-dfs-channels=all width=20/40/80mhz
add band=2ghz-n disabled=no frequency=2412,2437,2462 name=2G-N skip-dfs-channels=all width=20mhz
/interface wifi datapath
add bridge=bridge disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes group-encryption=ccmp group-key-update=1h management-protection=allowed name=sec2G
add authentication-types=wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes group-encryption=ccmp group-key-update=5m management-encryption=cmac management-protection=required name=sec5G
/interface wifi configuration
add channel=5G-AC country=Latvia datapath=datapath1 disabled=no mode=ap name=5G-AC-CFG security=sec5G security.ft=yes .ft-over-ds=yes ssid=mikroTik
add channel=2G-N country=Latvia datapath=datapath1 disabled=no mode=ap name=2G-N-CFG security=sec2G security.ft=yes .ft-over-ds=yes ssid=mikroTik
/interface wifi
# no connection to CAPsMAN
add channel=2G-N channel.band=2ghz-n .skip-dfs-channels=10min-cac .width=20/40mhz configuration=2G-N-CFG configuration.country=Latvia .manager=capsman .mode=ap .ssid=MikroTik-BC2423 datapath=datapath1 disabled=no radio-mac=2C:C8:1B:BC:24:23 \
add channel=5G-AC channel.band=5ghz-ac .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration=5G-AC-CFG configuration.country=Latvia .manager=capsman .mode=ap .ssid=MikroTik-BC2424 datapath=datapath1 disabled=no radio-mac=2C:C8:1B:BC:24:24 \
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=1h name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment=defconf interface=lte1 list=WAN
/interface wifi cap
set caps-man-addresses="" enabled=yes slaves-datapath=datapath1
/interface wifi capsman
set ca-certificate=WiFi-CAPsMAN-CA-2CC81BBC241E certificate=WiFi-CAPsMAN-2CC81BBC241E enabled=yes interfaces=bridge package-path="" require-peer-certificate=yes upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no identity-regexp=.*AC.* master-configuration=5G-AC-CFG name-format=5GHz-%I-AC supported-bands=5ghz-ac
add action=create-dynamic-enabled disabled=no identity-regexp=.*AC.* master-configuration=2G-N-CFG name-format=2GHz-%I-N supported-bands=2ghz-n
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1,8.8.8.8,9.9.9.9 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input dst-port=67-68 protocol=udp
add action=accept chain=forward dst-port=67-68 protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input protocol=udp src-port=67-68
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=drop chain=input comment="Drop (invalid)" connection-state=invalid
add action=accept chain=input comment="Accept (established, related)" connection-state=established,related
add action=reject chain=input comment="Reject everything else"
add action=accept chain=output comment="Accept all"
add action=drop chain=forward comment="Drop (invalid)" connection-state=invalid
add action=accept chain=forward comment="Accept (established, related)" connection-state=established,related
add action=reject chain=forward comment="Reject everything else"
/ipv6 nd
/system clock
set time-zone-name=Europe/Stockholm
/system logging
add topics=dhcp
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes
Waiting for your answers!
