What’s new in 5.26 (2013-Sep-04 15:01):
*) ssh - fixed denial of service;
What’s new in 5.25 (2013-Apr-25 15:59):
*) web proxy - speed up startup;
*) metarouter - fixed occasional lockups on mipsbe boards;
*) wireless - update required when using small width channel RB2011 RB9xx
caveat: update remote end/s before updating AP as both side are required to use new/same version for a link
What’s new in 5.24 (2013-Feb-19 15:29):
*) l2tp - fixed problem with reconnects when it added multiple ip addresses;
*) wireless - fixed AES encryption speed issues (upgrade suggested);
What’s new in 5.23 (2013-Jan-29 14:07):
*) lcd - changed gamma, which gives greater contrast
*) fix reboot when running on third party hypervisors;
*) ppp client - fixed possible loss of configuration after reboot for some modems;
*) fixed wifi led order on “SXT Lite5”;
What’s new in 5.22 (2012-Nov-23 09:28):
*) userman - fix PayPal “bad HTTP response”;
*) kvm - fixed possible ROS guest incomplete package installation;
*) l2tp server - added keepalive-timeout setting;
*) wireless - fixed RADIUS mac-caching;
*) wireless - fixed rare nv2 link stall;
*) metarouter - fixed system occasional lockup for 12s on RB4xx and RB7xx;
*) metarouter - fixed crash when FPU exception was raised in one of powerpc metarouters;
*) quickset - added HomeAP mode;
*) fixed “export compact” in “ip proxy”;
And other not revealed to public.
If you want official support, use 6.12 and contact your local dealer, it can suggest you if are one problem with your configuration, and can suggest to write or not one mail with problem description at support@mikrotik.com
If you want user support (this forum) use 5.26, the last 5.x,
update the BIOS [firmware] to the last version,
specify what RouterBoard you use, RouterOS version, BIOS [firmware] version, package installed,
post in the forum the result of “/export hide-sensitive compact” command
and wait if someone, not payed to do that, can help you.
Thanks.
