DHCP Client stuck searching
Winbox 6.36.2 on a hAP lite.
All ports on a bridge.
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=bridge1
The problem is that the hAP won’t obtain a DHCP lease.
It is stuck “searching” on a network with a CenturyLink Router as gateway (IPV4).
My Win10 Laptop obtains a DHCP lease fine and connects.
It should work, something is wrong with your config. Please export it and copypaste it here.
I have the same issue tried everything possible.. still no luck
Why is the dhclient on a bridge
