DHCP Clients don't resolve static DNS entries
after switching from FritzBox to MikroTik as my DHCP/DNS server, my clients stopped resolving short dns names.
i need to explicitly trigger regexp entries, otherwise dns resolve fails
root@fServer:~
#> ping -c 1 Monster
ping: Monster: Der Name oder der Dienst ist nicht bekannt [i](name or service is unknown)[/i]
root@fServer:~
#> ping -c 1 test.Monster
PING test.monster (192.168.109.3) 56(84) bytes of data.
64 bytes from monster (192.168.109.3): icmp_seq=1 ttl=128 time=0.149 ms
--- test.monster ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.149/0.149/0.149/0.000 ms
root@fServer:~
#> ping -c 1 Monster.lan
PING monster.lan (192.168.109.3) 56(84) bytes of data.
64 bytes from monster (192.168.109.3): icmp_seq=1 ttl=128 time=0.147 ms
--- monster.lan ping statistics ---
rtt min/avg/max/mdev = 0.147/0.147/0.147/0.000 ms
root@fServer:~
#> ping -c 1 test.Monster.lan
PING test.monster.lan (192.168.109.3) 56(84) bytes of data.
64 bytes from monster (192.168.109.3): icmp_seq=1 ttl=128 time=0.150 ms
--- test.monster.lan ping statistics ---
rtt min/avg/max/mdev = 0.150/0.150/0.150/0.000 ms
but dig has no problems resolving DNS entries:
root@fServer:~
#> dig Monster
; <<>> DiG 9.11.5-1-Debian <<>> Monster
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 43107
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;monster.                       IN      A
;; ANSWER SECTION:
monster.                10      IN      A       192.168.109.3
;; Query time: 1 msec
;; SERVER: 192.168.109.5#53(192.168.109.5)
;; WHEN: Do Nov 22 13:55:59 CET 2018
;; MSG SIZE  rcvd: 41
looking at the log on my MikroTik, i see the dns query packets for “ping -c 1 Monster” missing.
that means i probably messed up my dhcp config somewhere.
/ip address add address=192.168.109.5/24 interface=bridge1 network=192.168.109.0
/ip route add distance=1 gateway=192.168.109.1
/system ntp client set enabled=yes primary-ntp=192.168.109.1
/ip pool add name=dhcp_pool ranges=192.168.109.200-192.168.109.254
/ip dhcp-server add add-arp=yes address-pool=dhcp_pool disabled=no interface=bridge1 name=dhcp_v4
/ip dhcp-server config set store-leases-disk=never
/ip dhcp-server lease add address=192.168.109.9 allow-dual-stack-queue=no client-id=fServer
/ip dhcp-server network add address=192.168.109.0/24 dns-server=192.168.109.5 gateway=192.168.109.1 ntp-server=192.168.109.1 wins-server=192.168.109.9
/ip dns set allow-remote-requests=yes cache-max-ttl=1m servers=192.168.109.1
/ip dns static
add address=192.168.109.9 comment="File Server name" name=fServer ttl=10s
add address=192.168.109.9 comment="File Server match" regexp="(.+\\.)\?f[Ss]erver(\\.[Ll]an)\?" ttl=10s
add address=192.168.109.3 comment="Gaming Monster name" name=Monster ttl=10s
add address=192.168.109.3 comment="Gaming Monster match" regexp="(.+\\.)\?[Mm]onster(\\.[Ll]an)\?" ttl=10s
edit:
i am dumb. i forgot to set domain in dhcp config.
/ip dhcp-server network add address=192.168.109.0/24 dns-server=192.168.109.5 domain=lan gateway=192.168.109.1 ntp-server=192.168.109.1 wins-server=192.168.109.9
now “it just works”.
You can also encourage (read as force) people to use your DNS with the below as well, just make sure they are placed at the top of your NAT table.
add action=redirect chain=dstnat comment="DNS Loopback" dst-port=53 protocol=tcp src-address=192.168.109.0/24
add action=redirect chain=dstnat comment="DNS Loopback" dst-port=53 protocol=udp src-address=192.168.109.0/24
