DHCP Clients on LGH5 Bridge
Hello everybody,
I’m new in this Forum and with Mikrotik.
My router (192.168.178.1) makes the internet connection and also DHCP (192.168.178.70 -192.168.178.250).
Then I have 2 LGH5 (RadioA 192.168.178.50 and RadioB 192.168.178.51) to make a connection to another building.
The Bridge is working fine, i can send a ping to Google DNS 8.8.8.8 from RadioB.
But no Client on RadioB get a IP address or any connection to the internet.
What do I have to set on the two LGH5 so that the router assigns the IP addresses to the clients.
best regards from Germany Christian
Radio A and B wireless configuration modes ?
Hello Zacharias,
sorry for the delayed answer.
I have both LGH5 reset to factory (without any configuration). Then is set the IP on RadioA 192.268.278.50/24 and RadioB to 192.168.178.51/24.
then i set the bridge1 the Ports on Bridge1 ether1 and wlan1 and wireless enabled.
here the config on RadioA:
RadioA is bridge, RadioB is bridge station.
Thank you for your answer.
Best Regards Christian
I dont see anything wrong… are you sure the client does not get an IP?
If yes there must be a mistake somewhere else…
Yes no IP and also no internet if I assign an IP.
If you assigned a static IP with GW and DNS and still no internet then certainly you have a mistake(s) in your configuration…
