DHCP conflict
Hello! Ive got lame question but cant find answer by myself.
What we got rb2011uas at 6.49.13. DHCP server with single pull 192.168.1.2-192.168.1.200. Some clients get addreses in ip-pool-used adreses even if its client offline and these addresses cause a dhcp server conflict. All leases are Dynamic. How can i cleare this table or ?Also is it possible to combine DHCP with few static IPs or they must be excluded manualy from pool.
Would need to see the config:
/export hide-sensitive file=anynameyoulike
Remove serial and any other private info en post in between code tags by using the </> button.
IP reservations should not be part of the DHCP scope.
It should be easy to unscramble but we do need to see your config.
Thank you for your response!
dronesconfig.rsc (13.2 KB)
