Hello everyone.
I have a problem with my router. I have configured several VLANs working inside a bridge, but I don’t know why when I try to add another one, in the same way as I did the others it doesn’t work for me. The id of the Vlan that does not work is 30. When I try to connect to this network it does not give me a DHCP address. The rest of them all work correctly.
I put my configuration to see if you could help me to solve it.
Thank you very much for your help.
# aug/29/2022 14:44:57 by RouterOS 7.4.1
# software id = 72BE-WTA3
# model = RB4011iGS+
# serial number =
add fast-forward=no name=br_lan
set [ find default-name=ether3 ] mac-address=B8:69:F4:92:2E:1C
set [ find default-name=ether4 ] mac-address=B8:69:F4:92:2E:1D
set [ find default-name=ether5 ] mac-address=B8:69:F4:92:2E:1E
set [ find default-name=ether6 ] mac-address=B8:69:F4:92:2E:1F
set [ find default-name=ether7 ] mac-address=B8:69:F4:92:2E:20
set [ find default-name=ether8 ] mac-address=B8:69:F4:92:2E:21
set [ find default-name=ether9 ] mac-address=B8:69:F4:92:2E:22
set [ find default-name=ether10 ] comment="br wan movistar" mac-address=B8:69:F4:92:2E:23
set [ find default-name=ether2 ] comment="lan interface" mac-address=B8:69:F4:92:2E:1B name=inside
set [ find default-name=ether1 ] comment="wan interface" mac-address=B8:69:F4:92:2E:1A mtu=1592 name=outside
set [ find default-name=sfp-sfpplus1 ] l2mtu=2000 mac-address=B8:69:F4:92:2E:24
/interface vlan
add comment="vlan 3" interface=outside name=vlan3 vlan-id=3
add interface=ether10 name=vlan3_f vlan-id=3
add comment="vlan 6 movistar" interface=outside name=vlan6 vlan-id=6
add comment="vlan 10 staff" interface=br_lan name=vlan10 vlan-id=10
add comment="vlan 11 guest" interface=br_lan name=vlan20 vlan-id=20
add interface=br_lan name=vlan30 vlan-id=30
/interface pppoe-client
add add-default-route=yes comment="dialer movistar" disabled=no interface=vlan6 name=Dialer1 user=adslppp@telefonicanetpa
/interface lte apn
/ip ipsec peer
# This entry is unreachable
add name=peer1 passive=yes
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add enc-algorithms=aes-256-cbc,3des name=L2TP-Proposal pfs-group=none
add name=dhcp_vlan10 ranges=192.168.10.30-192.168.10.100
add name=dhcp_vlan20 ranges=192.168.20.2-192.168.23.254
add name=POOL_VPN_L2TP ranges=172.16.30.10-172.16.30.20
add name=dhcp_pool8 ranges=10.25.223.1-10.25.223.20
add name=dhcp ranges=192.168.0.33-192.168.0.88
add name=dhcp_fakevlan3 ranges=172.20.0.2-172.20.0.6
add name=dhcp_pool11 ranges=10.0.0.2/31
add name=dhcp_pool17 ranges=10.0.30.2-10.0.30.254
add name=dhcp_vlan30 ranges=192.168.30.2-192.168.30.254
add address-pool=dhcp_vlan10 interface=vlan10 lease-time=1d name=dhcp_staff
add address-pool=dhcp_vlan20 interface=vlan20 lease-time=3h name=dhcp_hotspot
add address-pool=dhcp interface=br_lan lease-time=1d10m name=dhcp_lan
add address-pool=dhcp_vlan30 interface=vlan30 lease-time=3h name=dhcp_test
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=172.16.30.1 name=VPN-L2TP remote-address=POOL_VPN_L2TP use-encryption=required
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,rest-api
add bridge=br_lan ingress-filtering=no interface=inside trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether3 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether4 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether5 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether6 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether7 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether8 trusted=yes
add bridge=br_lan ingress-filtering=no interface=ether9 trusted=yes
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set authentication=mschap2 default-profile=VPN-L2TP enabled=yes max-mru=1460 max-mtu=1460 use-ipsec=yes
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.0.1/24 comment=LAN interface=br_lan network=192.168.0.0
add address=192.168.10.1/24 comment="VLAN 10 - STAFF" interface=vlan10 network=192.168.10.0
add address=192.168.20.1/22 comment="VLAN 20 - GUEST" interface=vlan20 network=192.168.20.0
add address=192.168.1.1/24 interface=br_lan network=192.168.1.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add add-default-route=no disabled=yes interface=vlan3
add address=192.168.0.0/24 dns-server=80.58.0.33,8.8.8.8 gateway=192.168.0.1
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
add address=192.168.10.0/24 comment="VLAN 10 - Staff" gateway=192.168.10.1
add address=192.168.20.0/22 comment="VLAN 20 - Hotspot" gateway=192.168.20.1
add address=192.168.30.0/24 comment="VLAN 30 - TEST" gateway=192.168.30.1
set servers=8.8.8.8,9.9.9.9
/ip firewall address-list
add address=192.168.1.111 list=CCTV
add action=accept chain=input comment=IPSEC dst-port=500 protocol=udp
add action=accept chain=input comment=IPSEC protocol=ipsec-esp
add action=accept chain=input comment=IPSEC dst-port=4500 protocol=udp
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=drop chain=input comment="BLOQUEJA DURANT 24 hores qui fa 5 intents seguits de login SSH!" dst-port=22109 protocol=tcp src-address-list=black_list_ssh
add action=add-src-to-address-list address-list=black_list_ssh address-list-timeout=1d chain=input connection-state=new dst-port=22109 protocol=tcp src-address-list=ssh_stage4
add action=add-src-to-address-list address-list=ssh_stage4 address-list-timeout=1m chain=input connection-state=new dst-port=22109 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22109 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22109 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22109 protocol=tcp
add action=drop chain=input comment="BLOQUEJA DURANT 24 hores qui fa 5 intents seguits de login winbox!" dst-port=18291 protocol=tcp src-address-list=black_list_winbox
add action=add-src-to-address-list address-list=black_list_winbox address-list-timeout=1d chain=input connection-state=new dst-port=18291 protocol=tcp src-address-list=winbox_stage4
add action=add-src-to-address-list address-list=winbox_stage4 address-list-timeout=3m chain=input connection-state=new dst-port=18291 protocol=tcp src-address-list=winbox_stage3
add action=add-src-to-address-list address-list=winbox_stage3 address-list-timeout=3m chain=input connection-state=new dst-port=18291 protocol=tcp src-address-list=winbox_stage2
add action=add-src-to-address-list address-list=winbox_stage2 address-list-timeout=3m chain=input connection-state=new dst-port=18291 protocol=tcp src-address-list=winbox_stage1
add action=add-src-to-address-list address-list=winbox_stage1 address-list-timeout=3m chain=input connection-state=new dst-port=18291 protocol=tcp src-address-list=winbox_stage1
add action=drop chain=input comment="BLOQUEJA DURANT 24 hores qui fa 5 intents seguits de login telnet!" dst-port=22323 protocol=tcp src-address-list=black_list_winbox
add action=add-src-to-address-list address-list=black_list_winbox address-list-timeout=1d chain=input connection-state=new dst-port=22323 protocol=tcp src-address-list=winbox_stage4
add action=add-src-to-address-list address-list=winbox_stage4 address-list-timeout=3m chain=input connection-state=new dst-port=22323 protocol=tcp src-address-list=winbox_stage3
add action=add-src-to-address-list address-list=winbox_stage3 address-list-timeout=3m chain=input connection-state=new dst-port=22323 protocol=tcp src-address-list=winbox_stage2
add action=add-src-to-address-list address-list=winbox_stage2 address-list-timeout=3m chain=input connection-state=new dst-port=22323 protocol=tcp src-address-list=winbox_stage1
add action=add-src-to-address-list address-list=winbox_stage1 address-list-timeout=3m chain=input connection-state=new dst-port=22323 protocol=tcp src-address-list=winbox_stage1
add action=jump chain=hs-auth disabled=yes dst-port=465 jump-target=hs-smtp protocol=tcp
add action=jump chain=hs-auth dst-port=587 jump-target=hs-smtp protocol=tcp
add action=masquerade chain=srcnat disabled=yes out-interface=vlan3_f
add action=masquerade chain=srcnat comment="global nat" out-interface=Dialer1
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.20.0/24
add action=dst-nat chain=dstnat comment="CCTV TCP 6080 192.168.1.111" dst-port=6080 in-interface=Dialer1 protocol=tcp to-addresses=192.168.0.111 to-ports=6080
add action=dst-nat chain=dstnat comment="CCTV TCP 55677 192.168.1.111" dst-port=55677 in-interface=Dialer1 protocol=tcp to-addresses=192.168.0.111 to-ports=55677
add action=masquerade chain=srcnat out-interface-list=*2000010
/ip firewall service-port
set sip ports=5060,5061,5070
/ip hotspot
add address-pool=*D addresses-per-mac=1 idle-timeout=none interface=*16 login-timeout=1h name=hotspot1 profile=SandwiChez
/ip hotspot user
add name=admin
/ip ipsec policy
add proposal=L2TP-Proposal template=yes
/ip service
set telnet disabled=yes port=22323
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes port=22109
set api disabled=yes
set winbox port=18291
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/routing rip interface-template
add disabled=yes instance=*1 interfaces=vlan3 mode=passive
/system clock
set time-zone-name=Europe/Madrid
/system resource irq rps
set sfp-sfpplus1 disabled=no
/system scheduler
add interval=1d name=backup on-event="/system script run backup-email" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=mar/03/2019 start-time=06:00:00
