DHCP error after reboot
I’ve been using mikrotiks at my clients for few years now.
In this new place I have couple month’s old Hex2 5 port router.
2 weeks after install every time after a reboot DHCP doesn’t work right.
Logs show multiple instances of “ dhcp1 offering lease: ip: for :mac: without success”
And no device on dhcp can work.
Only way to fix it is to disable and re-enable dhcp server.
Is this a known issue? And is there permanent fix for it?
Any ideas?
Whats your DHCP config? Is it authoritative ?
which version ROS you use?
Im using 6.38.3, I was couple behind when issue started, update didn’t fix it.
Every time I reboot the mikrotik Im getting that error from all devices on the network, until I disable and re enable DHCP server.
Mike
What does it mean authoritative DHCP?
Look this topic http://forum.mikrotik.com/t/ros-6-38-serious-dhcp-server-problem/105259/1
