I’m a new user of Mikoritk.
I have notice some strange traffic coming from my hEX device.
My hEX seems to send 1 or 2 “DHCP Discover”(Malformed Packet) every second on the “lan” side.
What I have try so far:
-Reboot
-Flush my DHCP client and server config
-Disable DHCP package (the device keep sending the packets event with the package disable and after a reboot)
-Unplug every not used Ethernet port (including “Wan”)
-RouterOS 6.44.1 and 6.43.1
Other strange behavior(solved):
-Some device on my network was receiving some bad DHCP config (wrong gateway, wrong netmask and wrong DNS). Those setting seems to be a mix of the DHCP config received from my ISP, my local DHCP server config and some apparently random but coherent setting.
-Fix: I have flush my DHCP-server config and reset it.
-Start of the issue: after upgrading from 6.43.1 to 6.44.1
-This issue have bring me to sniff my network traffic to try to understand what was going on, at this time, I have notice the “DHCP Discover(Malformed Packet)”
I’m lost! I try to understand what occur and how to correct it.
Thanks,
Neurotox
RouterOs: 6.44.1
Device: rb750gr3
Firmware: mt7621L 6.44.1
(I have also try with 6.43.13)
ether1: To my ISP (cable modem)
ether2: To my AP (dhcp disable on the AP)
> /system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-mmips 6.44.1
1 system 6.44.1
2 X ipv6 6.44.1
3 X wireless 6.44.1
4 hotspot 6.44.1
5 mpls 6.44.1
6 routing 6.44.1
7 X ppp 6.44.1
8 dhcp 6.44.1
9 security 6.44.1
10 advanced-tools 6.44.1
> /interface print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1 ether 1500 1596 2026 B8:69:F4:XX:XX:FB
1 RS ether2-master ether 1500 1596 2026 B8:69:F4:XX:XX:FC
2 S ether3 ether 1500 1596 2026 B8:69:F4:XX:XX:FD
3 S ether4 ether 1500 1596 2026 B8:69:F4:XX:XX:FE
4 S ether5 ether 1500 1596 2026 B8:69:F4:XX:XX:FF
5 R ;;; created from master port
bridge1 bridge 1500 1596 B8:69:F4:XX:XX:FC
> /ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.0.1/24 192.168.0.0 bridge1
1 192.168.0.3/24 192.168.0.0 bridge1
2 D xxx.xxx.xxx.154/27 xxx.xxx.xxx.128 ether1
> /ip dhcp-server print
Flags: D - dynamic, X - disabled, I - invalid
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp1 bridge1 dhcp_pool2 10m
> /ip dhcp-server network print
Flags: D - dynamic
# ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
0 192.168.0.0/24 192.168.0.1 192.168.0.1,8.8.8.8,xx.xxx.xxx.28,xx.xxx.xxx.29
> /ip pool print
# NAME RANGES
0 dhcp_pool2 192.168.0.100-192.168.0.200
> /ip dhcp-client print detail
0 D ;;; internet detect
interface=ether1 add-default-route=yes default-route-distance=1 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound address=xxx.xxx.xxx.154/27 gateway=xxx.xxx.xxx.129 dhcp-server=xxx.xxx.xxx.193
primary-dns=xx.xxx.xxx.28 secondary-dns=xx.xxx.xxx.29 expires-after=23h3m58s
