DHCP from ISP’s router in Audience router as AP
I connected my audience router as bridge AP to my ISP’s router. ISP router serves as DHCP server providing 192.168.1.0/24 address range. Audience is connected via eth1 to ISP router with 192.168.4. Every device that connects to audience receives the address from 192.168.88.0/24 range.
Where on Audience I can configure it using ISP’s router DHCP ie 192.168.1.1.
I guess it’s been answered thousand times but please advise not an expert person as I need all devices at home to acquire IP from the same subnet ie 192.168.1.10-192.168.1.250. Thank you.
reset your audience and make your audience as bridge
Do you connect the Audience as a WiFi client to the ISP router?
That is not going to work correctly. You need to use a cable.
I believe he stated that its connected to the ISP router via ether1 (assuming cable?)
I think what you are asking is how do you connect your audience as simply an AP/Switch connected to the ISP router.
What confuses us is when you use the term bridge as it has many connotations.
If you want to use it simply to flow through the ISP router DHCP then read this for ap/switch
https://forum.mikrotik.com/viewtopic.php?t=182276
If so I highly recommend doing the config off bridge so to speak.
https://forum.mikrotik.com/viewtopic.php?t=181718
If on the other hand you want to keep the audience as a router (with its own subnets and NAT etc) and to pass on DHCP from the ISP router, then that is another magnitude of complex and a full set of requirements would need to be ascertained.
