Dhcp goes busy
I have a dhcp with 2 pools, 1 for each cnet.
Pool 1 is setup with pool 2 as the next pool. My problem however is that the addresses in pool2 gets a busy status all the time and I run out of ip’s. If I do a check status on the busy ones, they disappear and may be gone for 1-2 days before they are back as busy.
been running on Ros 3.13 and Ros 3.14
Noone knows ? here is a cut from the log today.. As you see it goes through every address in cnet2, assignit, then deassign it. The result is that that address comes up with an busy status in dhcp leases and a final result of that is an empty pool. I then have to “check status” of the busy ones to make them avaiable again.. very annoying
13:42:47 dhcp,info,debug Dhcp Server assigned xx.xx.xx.133 to 00:19:D2:0B:AE:CC
13:42:48 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.133 from 00:19:D2:0B:AE:CC
13:43:01 dhcp,info,debug Dhcp Server assigned xx.xx.xx.134 to 00:19:D2:0B:AE:CC
13:43:04 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.134 from 00:19:D2:0B:AE:CC
13:43:14 dhcp,info,debug Dhcp Server assigned xx.xx.xx.135 to 00:19:D2:0B:AE:CC
13:43:15 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.135 from 00:19:D2:0B:AE:CC
13:43:25 dhcp,info,debug Dhcp Server assigned xx.xx.xx.136 to 00:19:D2:0B:AE:CC
13:43:28 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.136 from 00:19:D2:0B:AE:CC
13:43:38 dhcp,info,debug Dhcp Server assigned xx.xx.xx.137 to 00:19:D2:0B:AE:CC
13:43:41 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.137 from 00:19:D2:0B:AE:CC
13:43:52 dhcp,info,debug Dhcp Server assigned xx.xx.xx.138 to 00:19:D2:0B:AE:CC
13:43:54 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.138 from 00:19:D2:0B:AE:CC
13:44:05 dhcp,info,debug Dhcp Server assigned xx.xx.xx.139 to 00:19:D2:0B:AE:CC
13:44:05 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.139 from 00:19:D2:0B:AE:CC
13:44:16 dhcp,info,debug Dhcp Server assigned xx.xx.xx.140 to 00:19:D2:0B:AE:CC
13:44:18 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.140 from 00:19:D2:0B:AE:CC
13:44:29 dhcp,info,debug Dhcp Server assigned xx.xx.xx.141 to 00:19:D2:0B:AE:CC
13:44:31 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.141 from 00:19:D2:0B:AE:CC
13:44:42 dhcp,info,debug Dhcp Server assigned xx.xx.xx.142 to 00:19:D2:0B:AE:CC
13:44:44 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.142 from 00:19:D2:0B:AE:CC
13:44:57 dhcp,info,debug Dhcp Server assigned xx.xx.xx.143 to 00:19:D2:0B:AE:CC
13:44:58 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.143 from 00:19:D2:0B:AE:CC
13:45:09 dhcp,info,debug Dhcp Server assigned xx.xx.xx.144 to 00:19:D2:0B:AE:CC
13:45:11 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.144 from 00:19:D2:0B:AE:CC
13:45:22 dhcp,info,debug Dhcp Server assigned xx.xx.xx.145 to 00:19:D2:0B:AE:CC
13:45:24 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.145 from 00:19:D2:0B:AE:CC
13:45:35 dhcp,info,debug Dhcp Server assigned xx.xx.xx.146 to 00:19:D2:0B:AE:CC
13:45:35 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.146 from 00:19:D2:0B:AE:CC
13:45:46 dhcp,info,debug Dhcp Server assigned xx.xx.xx.147 to 00:19:D2:0B:AE:CC
13:45:48 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.147 from 00:19:D2:0B:AE:CC
13:45:59 dhcp,info,debug Dhcp Server assigned xx.xx.xx.148 to 00:19:D2:0B:AE:CC
13:46:01 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.148 from 00:19:D2:0B:AE:CC
13:46:12 dhcp,info,debug Dhcp Server assigned xx.xx.xx.149 to 00:19:D2:0B:AE:CC
13:46:14 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.149 from 00:19:D2:0B:AE:CC
13:46:25 dhcp,info,debug Dhcp Server assigned xx.xx.xx.150 to 00:19:D2:0B:AE:CC
13:46:25 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.150 from 00:19:D2:0B:AE:CC
13:46:36 dhcp,info,debug Dhcp Server assigned xx.xx.xx.151 to 00:19:D2:0B:AE:CC
13:46:38 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.151 from 00:19:D2:0B:AE:CC
13:46:49 dhcp,info,debug Dhcp Server assigned xx.xx.xx.152 to 00:19:D2:0B:AE:CC
13:46:51 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.152 from 00:19:D2:0B:AE:CC
13:47:02 dhcp,info,debug Dhcp Server assigned xx.xx.xx.153 to 00:19:D2:0B:AE:CC
13:47:05 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.153 from 00:19:D2:0B:AE:CC
13:47:15 dhcp,info,debug Dhcp Server assigned xx.xx.xx.154 to 00:19:D2:0B:AE:CC
13:47:16 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.154 from 00:19:D2:0B:AE:CC
13:47:26 dhcp,info,debug Dhcp Server assigned xx.xx.xx.155 to 00:19:D2:0B:AE:CC
13:47:29 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.155 from 00:19:D2:0B:AE:CC
13:47:39 dhcp,info,debug Dhcp Server assigned xx.xx.xx.156 to 00:19:D2:0B:AE:CC
13:47:42 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.156 from 00:19:D2:0B:AE:CC
13:47:52 dhcp,info,debug Dhcp Server assigned xx.xx.xx.157 to 00:19:D2:0B:AE:CC
13:47:55 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.157 from 00:19:D2:0B:AE:CC
13:48:05 dhcp,info,debug Dhcp Server assigned xx.xx.xx.158 to 00:19:D2:0B:AE:CC
13:48:06 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.158 from 00:19:D2:0B:AE:CC
13:48:16 dhcp,info,debug Dhcp Server assigned xx.xx.xx.159 to 00:19:D2:0B:AE:CC
13:48:19 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.159 from 00:19:D2:0B:AE:CC
13:48:29 dhcp,info,debug Dhcp Server assigned xx.xx.xx.160 to 00:19:D2:0B:AE:CC
13:48:32 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.160 from 00:19:D2:0B:AE:CC
13:48:42 dhcp,info,debug Dhcp Server assigned xx.xx.xx.161 to 00:19:D2:0B:AE:CC
13:48:45 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.161 from 00:19:D2:0B:AE:CC
13:48:55 dhcp,info,debug Dhcp Server assigned xx.xx.xx.162 to 00:19:D2:0B:AE:CC
13:48:56 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.162 from 00:19:D2:0B:AE:CC
13:49:06 dhcp,info,debug Dhcp Server assigned xx.xx.xx.163 to 00:19:D2:0B:AE:CC
13:49:09 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.163 from 00:19:D2:0B:AE:CC
13:49:20 dhcp,info,debug Dhcp Server assigned xx.xx.xx.164 to 00:19:D2:0B:AE:CC
13:49:22 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.164 from 00:19:D2:0B:AE:CC
13:49:33 dhcp,info,debug Dhcp Server assigned xx.xx.xx.165 to 00:19:D2:0B:AE:CC
13:49:35 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.165 from 00:19:D2:0B:AE:CC
13:49:46 dhcp,info,debug Dhcp Server assigned xx.xx.xx.166 to 00:19:D2:0B:AE:CC
13:49:46 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.166 from 00:19:D2:0B:AE:CC
13:49:57 dhcp,info,debug Dhcp Server assigned xx.xx.xx.167 to 00:19:D2:0B:AE:CC
13:49:59 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.167 from 00:19:D2:0B:AE:CC
13:50:10 dhcp,info,debug Dhcp Server assigned xx.xx.xx.168 to 00:19:D2:0B:AE:CC
13:50:12 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.168 from 00:19:D2:0B:AE:CC
13:50:23 dhcp,info,debug Dhcp Server assigned xx.xx.xx.169 to 00:19:D2:0B:AE:CC
13:50:25 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.169 from 00:19:D2:0B:AE:CC
13:50:36 dhcp,info,debug Dhcp Server assigned xx.xx.xx.170 to 00:19:D2:0B:AE:CC
13:50:36 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.170 from 00:19:D2:0B:AE:CC
13:50:47 dhcp,info,debug Dhcp Server assigned xx.xx.xx.171 to 00:19:D2:0B:AE:CC
13:50:49 dhcp,info,debug Dhcp Server deassigned xx.xx.xx.171 from 00:19:D2:0B:AE:CC
13:51:00 dhcp,info,debug Dhcp Server assigned xx.xx.xx.172 to 00:19:D2:0B:AE:CC
etc until empty pool
what is this client that tries to get all the time different IP address?
the client is a customer with a dlink router with dlink bwl810 bridge that takes down the signal from one of our wireless ap’s if thats what you mean…
dlink router ↔ dlink bwl810 bridge ↔ ap
edit:
Im not sure if it only happends to this client, Ill check for that in the future. This started to happend after I moved the dhcp server from 2.9.x to 3.13/14
edit2:
Have looked at the router in question above and found an error on it where it just discarded the given ipadress almost instantly. Hopefully this will end a month of trouble :slight_smile:
