DHCP Grace Period
Does RouterOS support DHCP grace period? For example if the lease on an IP address expires it won’t be handed out to another client until the defined grace period (4 hours, etc) expires. Thanks.
No I don’t think so. You could just set you’re lease time longer.
http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server
upon end of lease period address is instantly available in the address pool. If you require longer lease time adjust that in lease settings.
