Hello. I’ve got two APs set as a DHCP client, with their address(es) that I set in the DHCP lease. The problem is, while those two APs are connected (to ether2 & ether3) and I was able to connect and surf the internet through them, the DHCP status keeps in “waiting” state. This made setting both APs really cumbersome because I had to connect to them through ethernet manually. Any ideas?
https://1080ppornlist.com/
Waiting means they do not Discover any DHCP servers…
ether2 and ether3 should be in bridge and dhcp server set on the same bridge!
Is this the case in your configuration?
