Should Mikrotik add this in the next possible release?
- Yes definately, I would like the option from which end of the IP Pool it gets the IP from.
- Yes definately, I would like it fixed so it gets the IP from the begining of the IP Pool, not the end.
- Ok sure, it seems a quick fix/option to add, why not.
- No, their attention should be focussed on fixing/adding popular items only.
I’ll probably need to email support for this, but I thought I’d check on here first, I did a search and didn’t find mention of this, also I can’t find any info on the wiki (besides the general description).
I’ve got a RB 493AH, with 5.1 (just updated to 5.5, still doing it), and have finally set it up to do DHCP for my network (mainly as an emergency replacement while I deal with a down Windows Server), I’ve inputted all the settings for DHCP server, interface, IP pool, static leases, etc.
Then I noticed the first client pick up an ip, but it wasn’t what I expected.
IP Pool
192.168.0.1-192.168.0.253
I expected it to get 192.168.0.1 as it’s the first ip in the pool, nothing else on the network is using it, no, it got 192.168.0.253 instead. I shortened the lease time and changed the range to end 252, it got .252. I changed it to 192.168.0.11-192.168.0.19, it picked up .19
I’ve looked for a reverse order option somewhere, I even entered the pool in reverse, eg. 192.168.0.19-192.168.0.11 (which I thought it would complain about, but no, it accepted it), but it didn’t make any difference.
Granted, this is purely an admin preference thing, and maybe my OCD, but I don’t like it, I want it to start at a lower number and go up, is there a way to do this I’m missing?
PS. Not to be confused with this post: http://forum.mikrotik.com/t/dhcp-problem/32443/1
Where it was reversing the IP e.g. 254.20.10.10 instead of 10.10.20.254.
PPS. Ah, I have found a post, not much help, and looks like this has been the behaviour for quite a few years: http://forum.mikrotik.com/t/dhcp-server-help/6088/1
Edit: I’ve added a Poll, but I’d like to point out only out of curiosity, since results can be skewed by all manner of things, politics, popularity, plus we all know there are people with nothing better to do than post negative comments on internet forums (we’ve all come across them). I don’t accept the Poll results as proof one way or another, still it might show what interest there is in this topic, since if people didn’t care they’d probably just ignore it without a poll, far quicker/easier to select a poll option than write an actual post (60+ views and only 8 replies at time of this post), unfortunately that can be both good and bad as I’ve just stated. Also, don’t know if support/devs themselves are voting, they’ll most likely vote no as not wanting any other additional work.
