I have an office building with a shared internet connection. Since one of the tenants also processes credit cards, for them to be PCI compliant, we put them behind a second router board.
So, in the building I have ISP->Routerboard1 (192.168.2.0)->Switch->Routerboard2 (192.168.88.0)
The issue I am having, and it started a while back, I’m just getting now getting tired of fighting on my own, is that both Routerboards are answering DHCP requests regardless of which Routerboard the client is connected to.
Example: Client is hard wired to R1, they still get an IP address from R2 or client is hard wired to R2 and they get an IP address from R1.
It also doesn’t matter if they are connected using WiFi.
I double checked to be sure DHCP relaying is turned off but I’m still at a loss.
I can confirm that R1 is a 951G-2HnD with Firmware Type ar9344, Factory FW 3.12, Current FW 3.33, and OS Version 6.43.2.
R2 should be the same, but I’m not on site and can’t verify.
Any help appreciated.
Thanks,
Westley
This sounds as either very wrong configuration or just incorrect wiring. Whatever reason it is, I am pretty sure that both LAN interfaces are somehow on same L2 segment (this is practically certain as your devices are getting IP randomly from one or second DHCP, even if they are connected directly to RB1)
I would guess that you connected RB2 LAN side to the same switch as RB1 LAN side.
To make this clear, could you explain your network map a bit better (add interface names, so it is clear which port is connected to which device, how are clients connected etc…)? Also, could you post config of your RB2? Use /export hide sensitive and find/replace every personal detail you don’t want to share.
The default config of an 951G-2HnD is:
Port 1 = WAN
Port 2-5 & WIFI = LAN
So to accomplish what you’re doing, you should plug cables in like this..
R1 Port 1 → Internet
R1 Port 2 → Client 1 LAN
R1 Port 3 → R2 Port 1 (You probably have this going to a different port?)
R2 Port 2 → Client 2 LAN
Then DHCP packets won’t cross over. However, Client 2 LAN can still access Client 1 LAN and you won’t be PCI Compliant. You could add firewall rules on R2, deny outbound packets with dest IP in R1 subnet (Except for the IP of R1)
Alternatively, you can accomplish your goal with 1 router.
Edit interface ether4, set master port to none
Edit interface ether5, set master port to ether 3
– At this point ports 2,3 and wifi are on client 1 LAN and ports 4 & 5 are client 2 LAN
– Assuming you want additional WIFIs, you can add them on the router.
Rename wifi name to wifi-LAN1
Add virtual Wifi, set SSID and passphrase and name it wifi-LAN2
Rename bridge-local to bridge-LAN1
Add another bridge, name=bridge-LAN2 and add port 4 and wifi-LAN2
– Now you have two LANs on the same router, but they can talk to each other. Add a firewall
Add forwarding rules. Default deny rule and then permit bridge-lan1 to go through to the internet, same with bridge-lan2, but not each other
– DHCP Servers: you already have a DHCP server on bridge-LAN1.
Add a 2nd DHCP Server and apply it to bridge-LAN2 with desired settings.
PCI Compliance has a lot of rules, I usually put a payment terminal on it’s own subnet so half the compliance stuff doesn’t apply.
I am going to have to go into the office to actually grab the config for R2. I tried to remote into it a couple of different ways and it just didn’t work.
I do have R1 Port 3 plugged into R2 Port 1. That was one of the first things I checked, but I will go double check all of that again.
The tenant using R2 has a printer, a couple of desktops, and a bunch of laptops that connect thru WiFi. Couple that with the fact that they occupy the entire first floor while the TELCO closet and everyone else is on the second floor, it just made more sense to put a separate unit downstairs for them.
Hopefully I can get there tomorrow morning before they leave for the day. They shut down at Noon on Friday’s.
westley
November 13, 2018, 9:12pm
5
Finally had a chance to come into the office.
Here are the configs for both routers.
Router A
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.13 14:47:55 =~=~=~=~=~=~=~=~=~=~=~=
nov/13/2018 14:47:51 by RouterOS 6.43.2
software id = A1CR-6TEN
model = 951G-2HnD
serial number = 4F45045C6476
add admin-mac=4C:5E:0C:5F:0B:A7 auto-mac=no fast-forward=no mtu=1500 name=
bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
country="united states" disabled=no distance=indoors mode=ap-bridge ssid=
"5043 6164" wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master-local speed=100Mbps
set [ find default-name=ether3 ] name=ether3-slave-local speed=100Mbps
set [ find default-name=ether4 ] name=ether4-slave-local speed=100Mbps
set [ find default-name=ether5 ] name=ether5-slave-local speed=100Mbps
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp ranges=192.168.2.100-192.168.2.199
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=
bridge-local lease-time=3d name=default
/queue simple
add name=VoIP packet-marks=VoIP priority=2/2 target=""
add max-limit=30M/30M name="Internal Network" packet-marks=no-mark priority=
3/3 target=bridge-local
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether4-slave-local
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether5-slave-local
set discover-interface-list=discover
add interface=ether1-gateway list=discover
add interface=ether2-master-local list=discover
add interface=ether3-slave-local list=discover
add interface=ether4-slave-local list=discover
add interface=ether5-slave-local list=discover
add interface=bridge-local list=discover
add interface=ether2-master-local list=mactel
add interface=ether3-slave-local list=mactel
add interface=ether2-master-local list=mac-winbox
add interface=ether4-slave-local list=mactel
add interface=ether3-slave-local list=mac-winbox
add interface=ether4-slave-local list=mac-winbox
add interface=ether5-slave-local list=mactel
add interface=wlan1 list=mactel
add interface=ether5-slave-local list=mac-winbox
add interface=bridge-local list=mactel
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
add address=192.168.2.254/24 comment="default configuration" interface=
ether2-master-local network=192.168.2.0
add address=a.b.c.d/29 interface=ether1-gateway network=a.b.c.d
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=
ether1-gateway
add address=192.168.2.0/24 comment="default configuration" dns-server=
192.168.2.254,8.8.8.8,8.8.4.4 gateway=192.168.2.254 netmask=24
set servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.2.254 name=router
/ip firewall address-list
add address=122.0.0.0/8 list=blocklist
add address=62.0.0.0/8 list=blocklist
add address=85.114.128.78 list=blocklist
add address=163.172.121.92 list=blocklist
add address=37.49.231.132 list=blocklist
add address=51.75.12.173 list=blocklist
add address=64.2.142.26 list=whitelist
add address=64.2.142.187 list=whitelist
add address=64.2.142.190 list=whitelist
add address=64.2.142.9 list=whitelist
add address=64.2.142.87 list=whitelist
add address=64.2.142.17 list=whitelist
add address=64.2.142.189 list=whitelist
add address=64.2.142.109 list=whitelist
add address=64.2.142.188 list=whitelist
add address=64.2.142.215 list=whitelist
add address=64.2.142.107 list=whitelist
add address=64.2.142.216 list=whitelist
add address=64.2.142.111 list=whitelist
add address=64.2.142.106 list=whitelist
add address=36.0.0.0/8 list=blocklist
add address=191.13.112.89 list=blocklist
add address=174.57.160.29 list=blocklist
add address=138.121.130.12 list=blocklist
add action=accept chain=input comment="default configuration" protocol=icmp
add action=drop chain=input dst-port=53 protocol=udp
add action=drop chain=input src-address=1.0.0.0/8
add action=drop chain=input src-address=60.0.0.0/7
add action=drop chain=forward disabled=yes src-address=80.0.0.0/4
add action=drop chain=input src-address=112.0.0.0/5
add action=drop chain=input src-address=124.0.0.0/7
add action=drop chain=input src-address=186.0.0.0/7
add action=drop chain=input src-address=189.0.0.0/8
add action=drop chain=input src-address=222.0.0.0/7
add action=drop chain=input comment="Blocklist on input" src-address-list=
blocklist
add action=drop chain=forward comment="Block on forward" src-address-list=
blocklist
add action=drop chain=forward comment=DHCP dst-port=67-68 protocol=udp
src-port=67-68
connection-state=established
connection-state=related
add action=drop chain=input comment="default configuration" disabled=yes
in-interface=ether1-gateway
add action=accept chain=forward comment="default configuration"
add action=drop chain=forward comment="default configuration"
connection-state=invalid disabled=yes
/ip firewall mangle
add action=mark-packet chain=prerouting dst-port=10000-20000 new-packet-mark=
VoIP passthrough=no protocol=udp src-port=10000-20000
add action=mark-packet chain=forward disabled=yes dst-address=a.b.c.d
new-packet-mark=VoIP passthrough=yes
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat comment=PrivateVPN dst-port=1194
in-interface=ether1-gateway protocol=udp to-addresses=192.168.2.252
to-ports=1194
add action=dst-nat chain=dstnat comment=SIP-UDP dst-port=5060-5061
in-interface=ether1-gateway protocol=udp src-address-list=whitelist
to-addresses=192.168.2.251 to-ports=5060-5061
add action=dst-nat chain=dstnat comment=SIP dst-port=5060-5061 in-interface=
ether1-gateway protocol=tcp src-address-list=whitelist to-addresses=
add action=dst-nat chain=dstnat comment=RTP dst-port=10000-20000
to-addresses=192.168.2.251 to-ports=10000-20000
add action=dst-nat chain=dstnat comment=SSH-Private dst-port=4444
in-interface=ether1-gateway protocol=tcp to-addresses=192.168.2.252
to-ports=22
add action=dst-nat chain=dstnat comment=SSH-Phone dst-port=22222
in-interface=ether1-gateway protocol=tcp to-addresses=192.168.2.251
to-ports=22
add action=dst-nat chain=dstnat comment=PrivateVPNTCP dst-port=943
to-ports=943
add action=dst-nat chain=dstnat comment=PrivateVPNHTTPS dst-port=443
to-ports=443
add action=dst-nat chain=dstnat comment="Voicemail Portal" dst-port=8086
protocol=tcp to-addresses=192.168.2.251 to-ports=80
add action=dst-nat chain=dstnat comment=PrivateVPNWebServer dst-port=81
to-ports=80
add action=dst-nat chain=dstnat comment=PBX dst-port=82 in-interface=
ether1-gateway protocol=tcp to-addresses=192.168.2.251 to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=6060-6061 protocol=tcp
to-addresses=192.168.2.252 to-ports=6060-6061
add action=dst-nat chain=dstnat disabled=yes dst-port=4040-4041 protocol=tcp
to-addresses=192.168.2.252 to-ports=4040-4041
add action=dst-nat chain=dstnat disabled=yes dst-port=82 protocol=tcp
to-addresses=192.168.2.103 to-ports=80
add action=dst-nat chain=dstnat comment="Private BDR" dst-port=4040-4041
protocol=tcp to-addresses=192.168.2.252 to-ports=4040-4041
add action=dst-nat chain=dstnat comment="Private Web Access" dst-port=8080
protocol=tcp to-addresses=192.168.2.252 to-ports=8080
add action=dst-nat chain=dstnat dst-port=83 protocol=tcp to-addresses=
192.168.88.1 to-ports=80
/ip proxy
set cache-path=web-proxy1 parent-proxy=0.0.0.0
add distance=1 gateway=a.b.c.d
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.2.253
set api disabled=yes
/system clock
set time-zone-name=America/Chicago
/system identity
set name=StayOut!
/system leds
set 0 interface=wlan1
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Router B
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.13 14:42:11 =~=~=~=~=~=~=~=~=~=~=~=
nov/13/2018 14:42:01 by RouterOS 6.43.2
software id = QHUC-EV22
model = 951G-2HnD
serial number = 4F4504CD03FF
add admin-mac=4C:5E:0C:5C:C2:B9 auto-mac=no fast-forward=no mtu=1500 name=
bridge-local
/interface wireless
country="united states" disabled=no distance=indoors frequency=2422 mode=
ap-bridge ssid=5CC2BD wireless-protocol=802.11
add name=mactel
add name=mac-winbox
/ip ipsec proposal
add name=dhcp ranges=192.168.88.100-192.168.88.199
bridge-local lease-time=2w name=default
add address=192.168.88.1/24 comment="default configuration" interface=
ether2-master-local network=192.168.88.0
add address=192.168.2.253/24 interface=ether1-gateway network=192.168.2.0
/ip dhcp-client
ether1-gateway
/ip dhcp-server lease
add address=192.168.88.253 client-id=1:0:1b:a9:bd:1b:69 mac-address=
00:1B:A9:BD:1B:69 server=default
add address=192.168.88.141 lease-time=14h mac-address=84:38:35:53:35:FE
use-src-mac=yes
add address=192.168.88.138 mac-address=9C:F3:87:AE:8C:48
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add action=drop chain=forward dst-port=67-68 in-interface=ether1-gateway
out-interface=ether1-gateway protocol=udp src-port=67-68
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add distance=1 gateway=192.168.2.254
/ip service
/system clock
/system leds
set silent-boot=no
/tool mac-server
Thanks,
Westley
