DHCP issues on a wireless bridge
I maintain 2 sites and recently Site 2 requested wireless network in addition to the fixed network. This seemed easy enough but I consistently got 169.xxx.xxx.xxx meaning that DHCP could not assign an address from the range. To further clarify the issue:
Network topology:
Site 1:
LTE CPE - provides an Internet connection and services wireless clients via DHCP
3 Repeaters - repeat the signal of the wireless LTE CPE, get addresses via DHCP
Fixed network clients eg. Laptop - addresses via DHCP
Mobile clients - addresses via DHCP
Switch - connects to the LTE CPE and then provides DHCP and Internet to the wireless bridge
RB411 - wireless bridge to connect to Site 2
Site 2:
RB411 - wireless bridge to connect to Site 1
Wireless AP - extends internet from Site 1 to Site 2
Fixed network clients - get addresses via DHCP
Mobile clients - get a DHCP address depending if they’ve been on the wireless network at Site 1. This is even with a different SSID.
Bottom line:
Wireless network users from Site 1 cannot wireless roam Site 2 and vice versa. It’s as if once on the network at one of the sites, users are locked out because “they are already on the network”.
I therefore need to hide Site 1 from Site 2 and have the networks completely separate, while pointing Site 2 to the Site 1 gateway which provides Internet access.
Anyone with some ideas? :slight_smile:
Anyone? :frowning:
In case someone else has this issue, I resolved to just put all clients, fixed and wireless, at Site 2 on static IP’s. Sorted.
Roaming between Site 1 and 2 isn’t an issue any more it seems.
Edit: I noted periods where the network would hang for minutes at a time. So while static IP’s worked, I still had random slow throughput.
do you use WDS?
  1. Like tgid said WDS
  2. eoip
  3. bridge (stp/rstp)
  4. routing
You have many possibilities how to solve this.
Thanks guys, I’ll mess around with those in my free time. In terms of effort though, static IP’s is the easiest. Yes, there is a bit of admin giving new users static IP’s but it’s not a big site. I’ll have to do some homework before trying those solutions.
Edit: three words that solved all my problems: UniFi, Zero-Handoff technology.
