DHCP Lease Active Host Name Issue.
I am facing a problem on Mikrotik DHCP server lease. When I have connect Fortinet phone with Mikrotik router its works properly but did not found Fortinet phone host name at DHCP Lease Active host name section. Others devices host name is prompt properly. When I have connect this phone with Fortigate firewall we are getting host name. What is the issue is here??
My physical topology is: Mikrotik router —BDCOM Switch-----Fortinet phone.
Mikrotik router is configured as a flat mode. I have configure here just a DHCP server.
 # nov/25/2029 08:50:19 by RouterOS 6.45.7
# software id = 7PS1-EM1G
# model = RouterBOARD 3011UiAS
# serial number = 8EEE09DF8B3F
add name=R&D
add disabled=yes name="WAN_Bridge[Cumilla Online]"
add disabled=yes name="WAN_Bridge[Race Online]"
set [ find default-name=ether1 ] comment="Race Online" disabled=yes name=\
    ether1_Race
set [ find default-name=ether2 ] comment="Office Vedio Conference [Polycom]" \
    disabled=yes name=ether2_VC
set [ find default-name=ether3 ] comment="Cumilla Online" disabled=yes name=\
    ether3_Cumilla
set [ find default-name=ether4 ] comment="Office IPPABX [Yeaster-100]" \
    disabled=yes name=ether4_IPPABX
set [ find default-name=ether5 ] comment="LAN[Cisco Switch]" disabled=yes \
    name=ether5_LAN
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] name=ether9_R&D
set [ find default-name=sfp1 ] disabled=yes
add name=dhcp_pool0 ranges=192.168.100.2
add name=dhcp_pool1 ranges=172.16.10.2-172.16.10.254
add address-pool=dhcp_pool1 disabled=no interface=R&D name=dhcp1
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
    up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
    up-port=1700
/queue simple
add max-limit=5M/5M name="Solution Team - Mr. Abdul Aziz" target=\
    192.168.1.115/32
add max-limit=100M/100M name="Solution Team - Mr. Toha" target=\
    192.168.1.111/32
add max-limit=10M/10M name="Director - Technial" priority=1/1 target=\
    192.168.1.102/32
add max-limit=1M/1M name="SCM - Mahbub WiFi" target=192.168.1.121/32
add max-limit=3M/3M name="MKT - Nazrul" target=192.168.1.107/32
add max-limit=5M/5M name="MKT - Towfiq" target=192.168.1.110/32
add max-limit=3M/3M name="Sales & Marketing - Mr. Riaj" target=\
    192.168.1.105/32
add max-limit=3M/3M name="Sales & Marketing - Mr. Rajib" target=\
    192.168.1.108/32
add max-limit=5M/5M name="MKT - Dewan" target=192.168.1.104/32
add max-limit=10M/10M name="Director - HR" priority=1/1 target=\
    192.168.1.103/32
add max-limit=10M/10M name="Diretor CEO - Jaynul" priority=1/1 target=\
    192.168.1.100/32
add max-limit=10M/10M name="Solution Team - Mr. Jahirul Islam" priority=1/1 \
    target=192.168.1.112/32
add max-limit=10M/10M name="NVR CCTV" target=192.168.10.10/32
add max-limit=3M/3M name="Sales & Marketing - Mr. Rasel " target=\
    192.168.1.109/32
add max-limit=5M/5M name="Technical Team - Mr. Naser" target=192.168.1.123/32
add max-limit=5M/5M name="Solution Team - Mr. Bikash" target=192.168.1.113/32
add max-limit=3M/3M name="EPI UPS - Md. Shamsuzzman" target=192.168.1.124/32
add max-limit=3M/3M name="Technical Team - Shakil (AutoCAD)" target=\
    192.168.1.122/32
add max-limit=10M/10M name="Solution Team - Mr. Asif" target=192.168.1.114/32
add max-limit=2M/2M name="Accounts - Mr. omar" target=192.168.1.117/32
add max-limit=5M/5M name="SCM - Mr. Mahubub " target=192.168.1.120/32
add max-limit=5M/5M name="SCM - Mr. Maruf" target=192.168.1.119/32
add max-limit=5M/5M name="Accounts - Mr. Suvoo" target=192.168.1.116/32
add max-limit=3M/3M name="Admin - Miss. Sumi" target=192.168.1.118/32
add max-limit=10M/10M name="Director Sayed Sir" priority=1/1 target=\
    192.168.1.101/32
add max-limit=5M/5M name=MKT-Shafiq target=192.168.1.106/32
add comment="Network For Technical" max-limit=1k/1k name=\
    "Network For Technical" target=192.168.1.0/24
/queue type
add kind=pcq name=WIFI pcq-classifier=src-address,dst-address \
    pcq-dst-address6-mask=64 pcq-rate=5M pcq-src-address6-mask=64
add kind=pcq name="Technical WIFI" pcq-classifier=src-address,dst-address \
/queue simple
add max-limit=10M/10M name=WIFI queue=WIFI/WIFI target=192.168.3.0/24
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge="WAN_Bridge[Race Online]" interface=ether2_VC
add bridge="WAN_Bridge[Race Online]" interface=ether1_Race
add bridge="WAN_Bridge[Cumilla Online]" interface=ether3_Cumilla
add bridge="WAN_Bridge[Cumilla Online]" interface=ether4_IPPABX
add bridge=R&D interface=ether9_R&D
add bridge=R&D interface=ether10
add address=103.54.36.130/29 comment=ISP-2 interface=\
    "WAN_Bridge[Race Online]" network=103.54.36.128
add address=43.239.75.85/29 comment=ISP-1 interface=\
    "WAN_Bridge[Cumilla Online]" network=43.239.75.80
add address=192.168.1.1/24 comment="LAN [This prefix for internet use.]" \
    interface=ether5_LAN network=192.168.1.0
add address=192.168.2.1/24 comment="LAN [This prefix for IP phone.]" \
    interface=ether5_LAN network=192.168.2.0
add address=192.168.3.1/24 comment="LAN [This prefix for WIFI.]" interface=\
    ether5_LAN network=192.168.3.0
add address=192.168.10.110/24 comment="LAN [This prefix for camera.]" \
    interface=ether5_LAN network=192.168.10.0
add address=172.16.10.1/24 interface=R&D network=172.16.10.0
add address=172.16.10.0/24 dns-server=1.1.1.1 gateway=172.16.10.1
/ip firewall address-list
add address=192.168.1.0/24 list="Internet Use only"
add address=192.168.3.0/24 list="Internet Use only"
add action=masquerade chain=srcnat src-address-list="Internet Use only"
add check-gateway=ping distance=1 gateway=103.54.36.129
add check-gateway=ping distance=10 gateway=43.239.75.81
/system clock
set time-zone-name=Asia/Dhaka
/system identity
set name="R&D Mikrotik"
/tool user-manager database
set db-path=user-manager
The hostname is normally provided by the host itself as it requests the IP configuration from the DHCP server. Use /tool sniffer to sniff the DHCP communication on phone startup into a file, and disconnect and re-connect a phone whose hostname is seen in the output of /ip dhcp-server lease print and the Fortinet phone. Once the phones come up, stop the sniffer, download the file from the Tik to your PC and open it using Wireshark. You should see the hostname Option to be present in the DHCP communication of a phone for which it is seen in /ip dhcp-server lease print, but the same Option will likely be missing in the DHCP communication of the Fortinet phone.
