DHCP Lease Issue
Hi Guys,
i got a problem with DHCP Client at the RB751-2hnd. Everytime the lease run out the interface will not get an ip.
So i must reboot the router to get back the ip address from our dhcp server.
This Problem came with the update to 6.0rc5.
At the moment i solved it by setting the ip static, but there must be a problem or something else.
Sorry for my bad englisch :slight_smile:
share your dhcp config here
Hi Samir,
How are you. I have a problem with my PCC setting. When i try to use FTP filezilla software for uploading. My connect d/c every time when both ips for on. But when one ip is disable at that time my ftp work good.
