Greetings Friends.
What does “busy” mean in Dhcp lease in Mikrotik.
bound i can understand but what is “busy” is the machine still trying to acquire the IP.
image sharing
- bad cable
- bad connectors
- bad machine
- bad software on machine
- bad switch (if there is one)
You get the point.
Looking at the options from 1-5, The device that shows “busy” should not be working but I can get ping reply and the device is working fine. So my newbie knowledge predicts it should be something else.
One of the device is a print server in which i have setup manual IP and the other is interface of Mikrotik device which has been bridged.
