I have serveral different DHCP Server with different IP ranges. But the script adds only one domain name to alle different leases. How do i make a difference betwean the different networks
What the script does is create static entries in dns for all dhcp leases to that they may be resolved by name easily. For instance, if dhcp1 is giving out leases on interface eth1 with a network tag of “network.lan”, you can have dns records created by script so that each lease gets resolved by hostname:
ex. mach1.network.lan = 192.168.2.100
The script works very well… the issue is that if your implementation is running more than one dhcp server. For instance, if dhcp2 is running off eth2 with a network tag of “second.lan” the script continually adds the “network.lan” tag to the addresses given out. I think what is needed is a script that can actually differentiate, if that is possible.
I will test this and let you know! I assume you need to change the “server1” and “server2” parameters to what they are on your specific device AND the “.dhcp.lan.local” and “.dhcp.hotspot.local” as well… (Thank you in advance!)
Just to play Devil’s Advocate, the second script on the op’s page above (I’ll paste it below) allows the usage of TTL to differentiate between statically added and dhcp added dns entries. In my travels I find this script is most commonly used over the first one as that ttl protects manually added entries from being overwritten via dhcp. Would you think it possible to add your script to this below?
# Domain to be added to your DHCP-clients hostname
:local topdomain;
:set topdomain "lan";
# Use ttl to distinguish dynamic added DNS records
:local ttl;
:set ttl "00:59:59";
# Set variables to use
:local hostname;
:local hostip;
:local free;
# Remove all dynamic records
/ip dns static;
:foreach a in=[find] do={
:if ([get $a ttl] = $ttl) do={
:put ("Removing: " . [get $a name] . " : " . [get $a address]);
remove $a;
/ip dhcp-server lease ;
:foreach i in=[find] do={
:if ([:len [get $i host-name]] > 0) do={
:set free "true";
:set hostname ([get $i host-name] . "." . $topdomain);
:set hostip [get $i address];
/ip dns static ;
# Check if entry already exist
:foreach di in [find] do={
:if ([get $di name] = $hostname) do={
:set free "false";
:put ("Not adding already existing entry: " . $hostname);
:if ($free = true) do={
:put ("Adding: " . $hostname . " : " . $hostip ) ;
/ip dns static add name=$hostname address=$hostip ttl=$ttl;
