DHCP leases wrong
Hello everyone!
I’m using a premade system and I don’t know how to do some things.
I’m configuring routerboard 1200 via winbox.
First the most important, when devices connect to Routerboard, it don’t make leases all of them, both on WLAN and on LAN, and if I add manually a static IP with the device’s MAC address, the device won’t get the IP I set before. But if I make a lease static it’s working.
How can I set if I want all devices to get (visible) lease?
Also I can’t update my routerboard via winbox. I go System → Packages and the guide says to click check update but I can’t see this button (even not on webfig).
Thanx in advice! :slight_smile:
I’m really stupid. Router didn’t get leases because a second (i didn’t know about it) DHCP server ran in the network.
