default offering lease 192.168.1.90 for 28:E1:4C:97:7B:D3 without success
dhcp lease changed by admin
default assigned 192.168.1.103 to 28:E1:4C:97:7B:D3
When the assgnement is static (.90) it doesn’t work. When I switch to dynamic (pook .100-120) it does.
When switching back to static it works once, then it starts failing again.
When in dynamic range, the GUI is garbled somehow, see picture (The D field to disable is dysfunctional and in the wrong place):
OK, it seems to be related to the ‘always broadcast’ option. All clients that had this option enabled started suddenly showing these problems. I checked in older backups and the options were the same before.. so something must have happened.
