Can I set the dhcp server to offer clients from two different pools/networks depending on option 60?
If one client is asking whit option 60 and the other askes with no option they should get two different adress from two pools?
Regards
Regards
[admin@mt] /ip dhcp-client option> add code=60 name=stuff value=0x18A000000A016501000A016501
[admin@mt] /ip dhcp-client> set 0 dhcp-options=stuff
this should be compatible with IPoE and such.
you can also set “dhcp” option 60 setting in the IP POOL settings.
