Hi all,
I got an issue running a DHCP-Server on my RB3011 and would apreciate an idea where or what to look for. What I have done so far:
- Setup is Router RB3011 ---- Switch1 ---- Switch3 ---- Cisco Phone
- Set up VLANs according to pcunites tutorial an help as described in my previous thread
- VLAN works, IP-Networks work, Routing between network works, everything fine so far.
- DHCP-Server per VLAN set up on the Router, execpt for VLAN10
- in VLAN10 there is a PiHole running as DNS and DHCP-Server
What happens: When plugging in the CiscoPhone CP7941 to a VLAN70 access-port on switch2 the DHCP-Server for VLAN70 reacts and offers a lease:
[admin@CoreRouter] /ip dhcp-server> lease print detail
Flags: X - disabled, R - radius, D - dynamic, B - blocked
0 D address=172.28.170.199 mac-address=00:23:5E:19:3D:92
client-id="1:0:23:5e:19:3d:92" address-lists="" server=dhcp-LAN70
dhcp-option="" status=offered expires-after=10s last-seen=20s
active-address=172.28.170.199 active-mac-address=00:23:5E:19:3D:92
active-client-id="1:0:23:5e:19:3d:92" active-server=dhcp-LAN70
host-name="SEP00235E193D92"
After 30 seconds, it disappears, sometimes stays another 30 seconds but latest then it disapears. I also tried to set a DHCP-Option, but to make sure that this doesn’t call a problem, I removed it again. Also changing “authoritative=after-2sec-delay” didn’t help. The bridge is configured with protocol-mode=none.
Here the exports and config I believe are relevant:
/ip dhcp-server> export
# jan/14/2021 19:15:35 by RouterOS 6.48
# model = RB3011UiAS
[usera@Router]/ip dhcp-server
add address-pool=MGMT_POOL disabled=no interface=MGMT_IFACE name=MGMT_DHCP
add address-pool=pool-LAN70 authoritative=after-2sec-delay disabled=no \
interface=IFACE_VLAN70 name=dhcp-LAN70
add address-pool=pool-LAN100 disabled=no interface=IFACE_VLAN100 name=\
dhcp-LAN100
add address-pool=pool-LAN200 disabled=no interface=IFACE_VLAN200 name=\
dhcp-LAN200
add address-pool=pool-LAN300 disabled=no interface=IFACE_VLAN300 name=\
dhcp-LAN300
add address=172.28.56.0/24 dns-server=192.168.2.220 gateway=172.28.56.254
add address=172.28.57.0/24 dns-server=192.168.2.220 gateway=172.28.57.254
add address=172.28.58.0/24 dns-server=192.168.2.220 gateway=172.28.58.254
add address=172.28.99.0/24 dns-server=192.168.2.220 gateway=172.28.99.254
add address=172.28.170.0/24 dns-server=192.168.2.220 gateway=172.28.170.254
[usera@Router] /ip dhcp-server> /ip pool print
# NAME RANGES
0 MGMT_POOL 172.28.99.100-172.28.99.110
1 pool-LAN70 172.28.170.100-172.28.170.199
2 pool-LAN100 172.28.56.100-172.28.56.199
3 pool-LAN200 172.28.57.100-172.28.57.199
4 pool-LAN300 172.28.58.100-172.28.58.199
[usera@Router] /ip dhcp-server> /interface bridge print
0 R name="bridge" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled
arp-timeout=auto mac-address=48:8F:5A:EA:01:35 protocol-mode=none
fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m
vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all
ingress-filtering=no dhcp-snooping=no
Any idea what I did wrong?
Update: I just disabled the DHCP-Server on the PiHole (other VLAN and Network) but makes no difference.
