I’m setting up a network under the 10.1.1.0/24 subnet behind a 192.168.0.1/24 network. The clients connecting to my network are offered ip’s from the parent network instead of my configured dhcp server. This seems to work, but I’d rather get it right and have the local network operate independently from the connection.
I’ve got four sxt’s configured as 10.1.1.21-24, with the 21 box connected to the parent network. Please see my setup below:
My dhcp server is configured on 10.1.1.22/msf-ap2, but clients are offered leases from msf-uplink.. Should I block broadcast packets in msf-ap1 firewall?
the current configuration:
caching dns server on msf-ap1 and nat masquerading from 10.1.1.0/24 to 192.168.0.1. dhcp server on msf-ap2. all ap’s have ethernet and wlan ports bridged.
[admin@msf-ap1] > export
# jun/16/2016 22:56:57 by RouterOS 6.35.4
# software id = 0FDY-HZPM
add name=msf-ap1-br1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country=norway disabled=no frequency=auto mode=bridge name=msf-lnk1 nv2-preshared-key=password nv2-security=enabled ssid=msf-lnk1 wds-default-bridge=msf-ap1-br1 wds-mode=dynamic-mesh wireless-protocol=nv2
/interface wireless nstreme
set msf-lnk1 enable-nstreme=yes
/queue interface
set msf-lnk1 queue=only-hardware-queue
add bridge=msf-ap1-br1 interface=ether1
add bridge=msf-ap1-br1 interface=msf-lnk1
add address=10.1.1.21/24 interface=msf-lnk1 network=10.1.1.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=msf-ap1-br1
/system identity
set name=msf-ap1
/system leds
set 0 interface=msf-lnk1
[admin@msf-ap2] > export
# jun/16/2016 22:59:26 by RouterOS 6.35.2
# software id = MTQ1-0LQF
add name=msf-ap2-br1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country=norway disabled=no frequency=auto mode=station-wds nv2-preshared-key=password nv2-security=enabled ssid=msf-lnk1 wds-default-bridge=msf-ap2-br1 wds-mode=dynamic-mesh wireless-protocol=nv2
set wlan1 enable-nstreme=yes
add name=msf-client-pool ranges=10.1.1.100-10.1.1.250
add add-arp=yes address-pool=msf-client-pool always-broadcast=yes disabled=no interface=msf-ap2-br1 name=msf-ap2-dhcp-srv
/queue interface
set wlan1 queue=only-hardware-queue
add bridge=msf-ap2-br1 interface=ether1
add bridge=msf-ap2-br1 interface=wlan1
add address=10.1.1.22/24 interface=ether1 network=10.1.1.0
add address=10.1.1.0/24 dns-server=10.1.1.21,8.8.8.8 gateway=10.1.1.22 netmask=24 ntp-server=80.89.32.121
set servers=8.8.8.8
add distance=1 gateway=10.1.1.21
/system identity
set name=msf-ap2
/system leds
set 0 interface=wlan1
[admin@msf-ap3] > export
# jun/16/2016 23:01:10 by RouterOS 6.35.2
# software id = 9JXK-VTPL
add name=msf-ap3-br1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country=norway disabled=no frequency=auto mode=bridge name=msf-lnk2 nv2-preshared-key=password nv2-security=enabled ssid=msf-lnk2 wds-default-bridge=msf-ap3-br1 wds-mode=dynamic-mesh wireless-protocol=nv2
/interface wireless wds
add disabled=no master-interface=msf-lnk2 name=wds1
set msf-lnk2 enable-nstreme=yes
add bridge=msf-ap3-br1 interface=ether1
add bridge=msf-ap3-br1 interface=msf-lnk2
add address=10.1.1.23/24 interface=ether1 network=10.1.1.0
set servers=10.1.1.21
add distance=1 gateway=10.1.1.22
/system identity
set name=msf-ap3
/system leds
set 0 interface=msf-lnk2
[admin@msf-ap4] >> export
# jun/16/2016 23:06:39 by RouterOS 6.35.2
# software id = 0IP9-RZSY
add name=msf-ap4-br1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no frequency=5260 name=msf-lnk2-rcv nv2-preshared-key=password nv2-security=enabled ssid=msf-lnk2
set msf-lnk2-rcv enable-nstreme=yes
add bridge=msf-ap4-br1 interface=msf-lnk2-rcv
add bridge=msf-ap4-br1 interface=ether1
add address=10.1.1.24/24 interface=ether1 network=10.1.1.0
add distance=1 gateway=10.1.1.23
/system identity
set name=msf-ap4
/system leds
set 0 interface=msf-lnk2-rcv
