DHCP offering lease without success to itself
Hi all!
I have an issue with the DHCP-Server in an RB3011. In the log files I get the message: DHCP offing lease for without success.
On the router itself 4 internal networks are running with 2 DHCP-Server. But there is no DHCP client on the router.
Is there any idea whats wrong and how to get rid of these messages (solving the issue not hiding the entries).
Thanks for your support!
BR,
Michael
The entry in the log file:
No entries in DHCP client:
Here you see the internal interface it tries to provide the lease.
Here is the config:
jul/21/2020 09:38:06 by RouterOS 6.47.1
software id = QVCN-N3DT
model = RouterBOARD 3011UiAS
serial number = 783D08D4BABD
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=yes name=sukSEs
add client-to-client-forwarding=no local-forwarding=yes name="sukSEs Guest"
set [ find default-name=ether1 ] name="ether1 WAN" speed=100Mbps
set [ find default-name=ether2 ] name="ether2 Office Net" speed=100Mbps
set [ find default-name=ether3 ] name="ether3 VoIP Net" speed=100Mbps
set [ find default-name=ether4 ] name="ether4 Guest WLAN" rx-flow-control=
auto speed=100Mbps tx-flow-control=auto
set [ find default-name=ether5 ] name="ether5 C5UAV" speed=100Mbps
set [ find default-name=ether6 ] disabled=yes name=ether6-master speed=
100Mbps
set [ find default-name=ether7 ] disabled=yes speed=100Mbps
set [ find default-name=ether8 ] disabled=yes speed=100Mbps
set [ find default-name=ether9 ] disabled=yes speed=100Mbps
set [ find default-name=ether10 ] disabled=yes speed=100Mbps
set [ find default-name=sfp1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full disabled=yes
/interface pppoe-client
add add-default-route=yes comment="Telekom DSL" disabled=no interface=
"ether1 WAN" name="Telekom PPPoE" use-peer-dns=yes user=
/interface l2tp-client
add allow-fast-path=yes comment="VPN Verbindung zu sukSEs-Backup" connect-to=
sukses-backup.synology.me disabled=no name=l2tp-out use-ipsec=yes user=
admin
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=sukSEs
add authentication-types=wpa2-psk encryption=aes-ccm name="sukSEs Guest"
/caps-man configuration
add country=germany datapath=sukSEs mode=ap name="2.4 GHz sukSEs" security=
sukSEs ssid=sukSEs
add country=germany datapath="sukSEs Guest" mode=ap name=
"2.4 GHz sukSEs Guest" security="sukSEs Guest" ssid="sukSEs Guest"
add country="germany 5.8 ap" datapath=sukSEs mode=ap name="5.8 GHz sukSEs"
security=sukSEs ssid=sukSEs
add country="germany 5.8 ap" datapath="sukSEs Guest" mode=ap name=
"5.8 GHz sukSEs Guest" security="sukSEs Guest" ssid="sukSEs Guest"
/caps-man interface
add comment="Capsman WLAN Besprechung" configuration="2.4 GHz sukSEs"
disabled=no l2mtu=1600 mac-address=CC:2D:E0:C4:34:27 master-interface=
none name="Besprechung 2.4 GHz sukSEs" radio-mac=CC:2D:E0:C4:34:27
radio-name=CC2DE0C43427
add configuration="2.4 GHz sukSEs Guest" disabled=no l2mtu=1600 mac-address=
CE:2D:E0:C4:34:27 master-interface="Besprechung 2.4 GHz sukSEs" name=
"Besprechung 2.4 GHz sukSEs Guest" radio-mac=00:00:00:00:00:00
radio-name=""
add configuration="5.8 GHz sukSEs" disabled=no l2mtu=1600 mac-address=
CC:2D:E0:C4:34:26 master-interface=none name="Besprechung 5.8 GHz sukSEs"
radio-mac=CC:2D:E0:C4:34:26 radio-name=CC2DE0C43426
add configuration="5.8 GHz sukSEs Guest" disabled=no l2mtu=1600 mac-address=
CE:2D:E0:C4:34:26 master-interface="Besprechung 5.8 GHz sukSEs" name=
"Besprechung 5.8 GHz sukSEs Guest" radio-mac=00:00:00:00:00:00
radio-name=""
add comment="Capsman WLAN B\FCro" configuration="2.4 GHz sukSEs" disabled=no
l2mtu=1600 mac-address=CC:2D:E0:10:6A:13 master-interface=none name=
"B\FCro 2.4 GHz sukSEs" radio-mac=CC:2D:E0:10:6A:13 radio-name=
CC2DE0106A13
CE:2D:E0:10:6A:13 master-interface="B\FCro 2.4 GHz sukSEs" name=
"B\FCro 2.4 GHz sukSEs Guest" radio-mac=00:00:00:00:00:00 radio-name=""
CC:2D:E0:10:6A:12 master-interface=none name="B\FCro 5.8 GHz sukSEs"
radio-mac=CC:2D:E0:10:6A:12 radio-name=CC2DE0106A12
CE:2D:E0:10:6A:12 master-interface="B\FCro 5.8 GHz sukSEs" name=
"B\FCro 5.8 GHz sukSEs Guest" radio-mac=00:00:00:00:00:00 radio-name=""
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=
aes-256-cbc,aes-192-cbc,aes-128-cbc,3des
add name=dhcp ranges=192.168.100.2-192.168.100.99
add name="Guest WLAN DHCP Pool" ranges=192.168.200.2-192.168.200.200
add name="sukSEs VPN" ranges=10.10.0.1-10.10.0.100
add name="C5UAV VPN" ranges=10.10.1.1-10.10.1.100
add address-pool=dhcp disabled=no interface="ether2 Office Net" lease-time=3h
name="Office DHCP"
add address-pool="Guest WLAN DHCP Pool" disabled=no interface=
"ether4 Guest WLAN" lease-time=1h name="Guest WLAN DHCP"
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 name="sukSEs IPsec" use-encryption=
yes
/queue simple
add dst="ether1 WAN" max-limit=1M/1M name="Guest WLAN" target=
"ether4 Guest WLAN"
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man manager
set ca-certificate=CAPsMAN-CA-CC2DE01C9590 certificate=CAPsMAN-CC2DE01C9590
enabled=yes require-peer-certificate=yes
add comment=defconf interface="ether2 Office Net"
add comment=defconf disabled=yes interface=sfp1
add disabled=yes interface="ether5 C5UAV"
add disabled=yes interface=ether7
add disabled=yes interface=ether8
add disabled=yes interface=ether9
add disabled=yes interface=ether10
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=discover
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set authentication=mschap2 default-profile="sukSEs IPsec" enabled=yes
use-ipsec=yes
add interface="ether2 Office Net" list=discover
add interface="ether3 VoIP Net" list=discover
add interface="ether4 Guest WLAN" list=discover
add interface="ether5 C5UAV" list=discover
add interface=sfp1 list=discover
add interface=ether6-master list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add list=discover
add list=mactel
add list=mac-winbox
add interface="Telekom PPPoE" list=WAN
add address=192.168.100.1/24 interface="ether2 Office Net" network=
192.168.100.0
add address=192.168.99.1/24 interface="ether3 VoIP Net" network=192.168.99.0
add address=192.168.200.254/24 interface="ether4 Guest WLAN" network=
192.168.200.0
add address=192.168.101.1/24 interface="ether5 C5UAV" network=192.168.101.0
add address=192.168.100.0/24 comment=Office dns-server=
192.168.100.200,8.8.8.8,8.8.4.4 gateway=192.168.100.1 netmask=24
ntp-server=192.168.100.1
add address=192.168.200.0/24 comment="Guest WLAN" dns-server=8.8.8.8,8.8.4.4
gateway=192.168.200.254 netmask=24 ntp-server=192.168.200.254
set allow-remote-requests=yes servers=192.168.100.200,8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.100.110 name=sukses.synology.me type=A
/ip firewall address-list
add address=192.168.200.0-192.168.200.200 list=GuestWLAN
add address=192.168.100.1-192.168.100.254 list=allowed_to_router1
add address=192.168.100.0/24 list=DNS-access
add address=192.168.99.0/24 list=DNS-access
add address=192.168.200.0/24 list=DNS-access
add address=192.168.99.1-192.168.99.254 list=allowed_to_router2
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=accept chain=input comment="VPN Mikrotik" disabled=yes
in-interface="Telekom PPPoE" protocol=udp src-port=1701,500,4500
add action=accept chain=input disabled=yes in-interface="Telekom PPPoE"
protocol=ipsec-esp
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface="Telekom PPPoE"
"Guest WLAN excluded from fasttrack for simple queue processing"
connection-state=established,related src-address=192.168.200.0/24
connection-state=established,related dst-address=192.168.200.0/24
"Drop Guest WLAN to Office, VoIP or C5UAV" in-interface=
"ether4 Guest WLAN" out-interface="!Telekom PPPoE"
"Access to Router restricted auf 192.168.99.1 - 192.168.99.253"
src-address-list=allowed_to_router2
"Access to Router restricted auf 192.168.100.1-192.168.100.253"
src-address-list=allowed_to_router1
"Allow internal DNS requests, deny WAN DNS requests" dst-port=53
in-interface="ether2 Office Net" protocol=tcp
add action=accept chain=input dst-port=53 in-interface="ether2 Office Net"
protocol=udp
add action=accept chain=input dst-port=53 in-interface="ether3 VoIP Net"
protocol=tcp
protocol=udp
add action=drop chain=input dst-port=53 protocol=udp
add action=drop chain=input dst-port=53 protocol=tcp
"Allow connections established by router" connection-state=established
add action=drop chain=input comment="Drop access to Router"
add action=masquerade chain=srcnat comment="defconf: masquerade" dst-address=
!192.168.178.131 out-interface="Telekom PPPoE"
add action=masquerade chain=srcnat comment="sukSEs-Backup for Backup"
dst-address=192.168.178.131 out-interface=l2tp-out
add action=dst-nat chain=dstnat comment="L2TP/IPSec to Synology DS1517+"
dst-address-type=local dst-port=1701 in-interface="Telekom PPPoE"
protocol=udp to-addresses=192.168.100.110 to-ports=1701
add action=dst-nat chain=dstnat dst-address-type=local dst-port=500
in-interface="Telekom PPPoE" protocol=udp to-addresses=192.168.100.110
to-ports=500
add action=dst-nat chain=dstnat dst-address-type=local dst-port=4500
to-ports=4500
"Active Backup for Business to Synology DS1517+" dst-address-type=local
dst-port=5510 in-interface="Telekom PPPoE" protocol=tcp to-addresses=
192.168.100.110 to-ports=5510
add action=dst-nat chain=dstnat comment="SIP to Mitel 104" dst-address-type=
local dst-port=5070 in-interface="Telekom PPPoE" protocol=udp
to-addresses=192.168.99.2 to-ports=5070
add action=dst-nat chain=dstnat dst-address-type=local dst-port=5080
in-interface="Telekom PPPoE" protocol=udp to-addresses=192.168.99.2
to-ports=5080
/ip firewall service-port
set sip disabled=yes
add comment="sukSEs-Backup f\FCr Backup" distance=1 dst-address=
192.168.178.0/24 gateway=l2tp-out
/ip service
set winbox address=192.168.100.0/24,192.168.99.0/24,10.0.0.0/24,10.2.0.0/24
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/lcd
set default-screen=stats-all
/ppp secret
add name=test1 profile=default-encryption service=l2tp
add name=test2 profile=default-encryption service=l2tp
/snmp
set enabled=yes trap-generators=temp-exception,interfaces,start-trap
trap-version=2
/system clock
/system identity
set name=RB3011
/system ntp client
set enabled=yes primary-ntp=129.70.132.37 secondary-ntp=87.118.124.35
/system ntp server
set enabled=yes
/system script
add dont-require-permissions=no name=RemoveSIP owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/
ip firewall connection remove [/ip firewall connection find where connecti
on-type="sip" and src-address~"192.168.99.2"]"
/tool e-mail
set address=smtp.office365.com from= port=587 start-tls=yes user=
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
If you disconnect the office network and connect on these port a computer, the message still showing?
Regards.
problem stays.
I solved it now this way, which is not the optimum way. I made the DHCP lease static and blocked it. Since this the log message is gone.
BR,
Michael
Try removing the invalid bridge port member “ether2 Office Net” (in fact they are all invalid since there is no bridge, but the others are disabled):
add comment=defconf interface=“ether2 Office Net”
add disabled=yes interface=“ether5 C5UAV”
removed the bridge ports, but no changes. I stay now with blocking the lease.
BR,
Michael
Also try disabling internet detection:
set detect-interface-list=none
thanks, it works for me with same problem “DHCP offering lease without success to itself”
