I’m getting multiple messages in my log file where it’s failing to assign a lease to almost any new host requesting one.
New hosts just sit int he DHCP lease table with status offered and then eventually drop out. When enabling logging for DHCP it shows the discovery packet, the offer, but never gets an ack from the client…
a cisco switch (a 2600 and a 1900) that is set to get its IP address via DHCP…it will show offered and then count down 30 sec and do it again.
this problem wifi laptop that kept connecting and disconnecting like 20 seconds later an extensive data loss (even though it had a -63 RSSI)
I’ve only been with MT during 2.9 and this dhcp thing has been consistant across versions..i’m not saying its a problem with MT, but it is unusual as my other cisco switches have no issue getting an IP via dhcp from my other routers.
hi all i have rb750gl with v5.25 and pc with v5.24 and both show same problem (dhcp offering lease without success) i find it show up on a pc or laptop with windows 7 and ipv6 enable some pcs work after disable ipv6 sum fix with static ip but any other solution without consumer interference will be more better
