DHCP on one port
Hi Guys,
I am setting up a VOIP service and the ISP provided a Mikrotik 750gl to bond the 2 DSL modem together. The device is setup to work with the sonicwall which provide the IP for the LAN.
I want to setup my VOIP system directly on a switch and then to the mikrotik box and have the mikrotik work as a dhcp. Can this mikrotik provide dhcp on one port while having a static on another?
I am new to this device, any help would be greatly appreciated.
Thanks!
SB
Sure. If you post “/export compact” we could give you a little better direction.
